HUGE 3D PRINTER LOT!!!
Posted by gmh39
November 06, 2016 09:11PM
I am looking at selling the printer farm that I am in the middle of building. Right now there are 5 Ormerod style printers that are about 80% finished. Only a few things need to be mounted and the wiring needs to be done. Also included are A TON of parts to build about 10-12 more printers. I am located in the NYC area. Local is preferred, but I can ship if you cover the cost. I am looking to get $2000 OBO + shipping + Paypal (I am open to any reasonable offer).
PICS:
[www.dropbox.com]
WHAT’S INCLUDED:
5 – partially assembled Ormerod 2 printers (I replaced most of the laser cut parts with printed parts)
-heated bed installed
-endstops installed
-Hotend mounted
-Power supply mounted
-RAMPS board mounted
-Wiring
-Filament
-2.5 KG spooled ABS
-~850g of loose filament (ABS/PLA)
-As-IS Electronics (untested, may work)
4 - Duet 0.6
1 - Duet Expansion
1 – RAMPS 1.4
1 – RepRap Discount Smart Controller LCD
2 – Melzi V2.0 boards
6 – RepRapPro Proximity Sensors
-LCD cables
Makerbot Replicator heated bed
2 – Makerbot Replicator glass plates
sheet of BuildTak
Makerbot Replicator 2 acrylic plate
Motor wires
Power plugs
6 - RepRapPro Ormerod hotends
10 – fans
Heat shrink
GT2 belts
Lasercut parts for Ormerod 2 and Prusa i2
15 – 626Z ball bearings
38 – LM8UU linear bearings
9 –LM12UU linear bearings
12 – LM6UU linear bearings
14 – 623Z ball bearings
4 - 6mm bushing
33 – 8mm bushing
4 – 2040 x 350mm aluminum extrusion
Metal electronics housing
11 – MK2a heated beds
9 – MK2a-sized glass plates
10 – MK2a-sized aluminum heat spreaders
50 – NEMA 17 motors
8 – NEMA 14 motors
48 – 470mm M8 threaded rod
68 – 370mm M8 threaded rod
49 - 330mm M8 threaded rod
3 – 410mm M8 threaded rod
9 – 240mm M8 threaded rod
10 – 200mm M8 threaded rod
3 – 260mm 6mm smooth rod
1 – 490mm 12mm smooth rod
6 – 350mm 12mm smooth rod
10 – 350mm 8mm smooth rod
16 – 400mm 8mm smooth rod
13 – 430mm 8mm smooth rod
1 – 370mm M8 threaded rod
18 – 250mm M8 threaded rod
8 – 285mm M6 threaded rod
12 – 185mm M6 threaded rod
2 – 165mm M6 threaded rod
3 – 165mm M5 threaded rod
17 – 215mm M5 threaded rod
33 – heated bed springs
16 – build plate clips
Box of crimp terminals
9 – 240 tooth closed loop GT2 betls
Large bundle of CAT5 cable
40 – 10k thermistors
Misc. lengths of GT2/MXL belts
4 – Assembled heated beds
2 – chinese E3D clones (clogged)
Printrbot Ubis (clogged)
14 – 10x3x4 ball bearing
14 – 12x3x4 flanged ball bearing
35 – 608ZZ ball bearing
6 – RAMPS 1.4 w/ 4 A4988 drivers
7 – RepRap Discount Smart Controller LCDs
Misc. electronics parts
Multiple large bag of hardware
PICS:
[www.dropbox.com]
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
Re: HUGE 3D PRINTER LOT!!!
November 17, 2016 07:37PM
I AM WILLING TO SELL THE PARTS INDIVIDUALLY!!
PM ME WITH THE PARTS YOU WANT AND AN OFFER!!!
greghoge.com
December 04, 2016 11:19AM
December 23, 2016 08:50PM
Why did you buy all of this?
January 18, 2017 06:45PM
It is left over from printers I have bought and sold.
greghoge.com
February 21, 2017 01:10PM
Do you sell in smaller individual batches? I'm interested in the motors
March 02, 2017 04:42AM
March 05, 2017 10:36PM
