RapidBot is our new 3D printer with high quality Linear Motion Guide which offer more advantage with printing quality. smiling smiley
You Can Check out videos also here : Video 1
Video 2
You can also download Manual RapidBot Manual
This kit contains all that you need, to make a fully working RapidBot 3D Printer (build size 22 x 22 x 16.5 cm)
This kit comes standard with additional items such as: : kapton tapes, heated bed for ABS & PLA, power supply, usb cable, few mtr PLA , Linear motion guide ,flange Bearings,flange nut etc to make sure it’s a complete kit.
• Overall size 38.2 x 38.75 x 36.93 cm
• Build size 22 x 22 x 16.5 cm
Features of RapidBot 3D Printer
1. It using high quality linear motion guides
2. Very easy to build, just 6 hours
3. Accurate and easy belt placement
4. Large build volume with easy accesibility
5. Uses high quality acrylic from:www.perspex.co.uk
6. Integrated power supply for both Gen6 and Heatbed
7. Uses high quality aluminium pulley with T2.5 belts, to give high accuracy
8. Self locking design ensures rigid frame with easy steps(Without need of any measurements, during building)
This complete RapidBot 3D Printer kit contains :
• Generation 6 Electronics - including opto's on correct cable lengths with molex connectors and high temp heat cables for connecting Heater and Thermistor
• All hardware cut bearings, bars, studding & bolts, nuts, washers, , Linear motion guide ,flange Bearings,flange nut etc
• All acralick cut sheets (Side plates, Bottom plate, Top plate, Middle plate, Y frog support, Y-frog, Extruder base, Extruder motor plate, Heated printbed and opto-flag)
• M8 Threaded rods (330 mm)
• Chrome plated Smooth rods (330 mm)
• Printed plastic parts - plastic set (Pulleys, Clamps, Holder, Extra fan support, etc) & Extruder plastics for J Hotend
• Motor set of 4 - including correct cable lengths and Molex connectors (plug and play with Gen6 electronics)
• M4 Brass insert piece - for direct drive on motor shaft (5.1mm inner diameter)
•J Hot end partially pre-assembled, including Heater block, G550 Thermistor, Heat Resistor, Cooling fan, etc
• Silicone sealant (used for placing Thermistor and Resistor in Heater block)
• Kapton tape 15mm (Insulation of Thermistor legs)
• Kapton tape 40mm (To print on)
• Set of 4 Heater blocks, 4 x 1.0 Ohm (for Heated printbed)
• Cooling paste (To use between Printbed and Heater blocks)
• PTFE strain-relief
• X, Y and Z belts for RapidBot 3D Printer
• Power Supply 96W, Input: AC 100-240V, 50-60Hz, 1.3A, Output: DC 15V~20V, 3.5A
• USB and Power supply cables
• Plastic tie
• Extras such as Optos, Magnetic leveler, Forceps, Few mtr of PLA for first
For More Information you can visit
WWW.makemendel.com
You can write to us at
support@makemendel.com
