Printrboard Electronics
• Offers Improved production grade by adding heatbed and SD card support , Allegro stepper drivers, Also elimination of the FTDI UART chip
• Printrboard is by far the fastest and most reliable Electronics.
• Printrboard works great with any RepRap: Prusa, Mendel, Printbot, Rapidbot,Orca etc.
Features :
• Atmel
AT90USB1286 Microcontroller
• Four integrated Allegro A4982 Stepper
• Four 5V Endstop Connectors Supplied
• OnBoard SD Card Slot
• 2 N-MOSFETs for Extruder and Heatbed control
• 1 N-MOSFET for low power Fan or motor
Revision D
• Green Power LED
• 4 layer, 2oz Cu PCB with ENIG Finish -- Excellent current handling & thermal dissipation
This Printrboard Electronics Set Includes :
LUFA CDC Bootloader* and Marlin RC2 firmware Pre-Installed
• 3 Pieces of 3 Pin Molex with Mechanical switch Pre Soldered.
• 2 Pieces of 2 Pin High Temperature Molex (for Thermistor).
• 1 Piece of 2 Pin Molex (for Fan).
• 2 Pieces of 4 Pin High Temperature Molex (for Heaters).
• 1 Piece of Micro USB cable.
• Resistor
All Molex are 600 mm Long.
Special Prices:
For 50 Pcs: 87.5 USD
For 100 Pcs : 85 USD
If you have any question you can write us at
[email protected]
