After a long wait the boards are finally available!
Major features
Atmega2560
Powerful Atmega2560 processor with 256 kB memory, running at 16Mhz
Thermo couple
On board support for connecting a thermo couple
SD Card
Autonomous printing from Micro SD card on board
LCD support
Hooking up a LCD is pretty easy. The Wiring is compatible with most LCD screens. We do not sell the required wiring yet, but you can use 6x2-wire cable.
Four MOSFETs
The board has 4 MOSFETs (4x 150A) to support many needs.
Up to 5 stepper drivers
Compatible with RAMPS, 5 slots for stepper drivers (not included). Modularized to make replacement easy for damaged drivers.
Support for many peripherals
The board's functions can be easily extended with LCD, keypad etc. See the connectors section for more information
reprapworld.com]
reprapworld.com
PLA, ABS, PETG multiple colors (3 and 1.75 mm) €16,49 / kg
Megatronics 3.0 €79.99 /
Minitronics €37,19
