RapidBot 2.0 3D Printer Kit (Unassembled) [worldwide + $699.00 USD]
Posted by tejal
October 15, 2012 02:18AM
Hello Everybody,
RapidBot 2.0 Unassembled Kit :
This kit contains all that you need, to make a fully working RapidBot 2.0 3D Printer (build size 22 x 22 x 16.5 cm) .
This kit comes standard with additional items such as: : kapton tapes, heated bed for ABS & PLA, power supply, usb cable, few mtr PLA , Linear motion guide ,flange Bearings,flange nut etc to make sure it’s a complete kit.
Technical Specification :
• Machine size 400 mmx 200 mm x 320 mm
• Build size 220 mm x 220 mm x 165 mm
• Nozzle Diameter (mm) : 0.35
• Layer Thickness (mm) : 0.2
• Speed (mm/s) : 60
• Positionning Precision : 27 microns
• Input Format : STL
• Software : Pronterface
•System Copatibility : Windows 7 and Vista
• Power Supply : ATX, 450W
• Weight (KG) : 12
Features of RapidBot 2.0 3D Printer
1. It using high quality linear motion guides
2. Integrated Spool Holder
3. Very easy to build (Just 6 Hours), Compact Design.
4. Improved Extruder Design and Z axis.
5. Accurate and easy belt placement
6. Large build volume with easy accesibility.
7. Uses high quality acrylic from:www.perspex.co.uk
8. Integrated power supply for both Printrboard and Heatbed.
9. Uses high quality aluminium pulley with T2.5 belts, to give high accuracy.
10. Self locking design ensures rigid frame with easy steps(Without need of any measurements, during building) .
For more information visit our site : [makemendel.com]
For any query drop your mail at : support@makemendel.com
open | download - IMG_4359.JPG (166 KB)
