Mini differential IR height sensor board June 10, 2015 06:00AM |
UK inc. VAT 29.82 EU VAT paid 37.83 Rest of world 32.52
Re: Mini differential IR height sensor board June 11, 2015 09:00AM |
Re: Mini differential IR height sensor board June 13, 2015 01:04AM |
Re: Mini differential IR height sensor board June 13, 2015 04:15AM |
jlmccuan
Can you set the trigger distance further away so that the board is above the nozzle somewhat to avoid it hitting a print that has lifted or curled?
Re: Mini differential IR height sensor board June 16, 2015 02:15PM |
Re: Mini differential IR height sensor board June 22, 2015 08:40AM |
Re: Mini differential IR height sensor board June 22, 2015 02:13PM |
Re: Mini differential IR height sensor board June 22, 2015 02:38PM |
Re: Mini differential IR height sensor board June 22, 2015 05:35PM |
shadowphile
How does your design not fail with heated beds? It seems like the background IR would swamp your sensors. Just curious. I am ready to dump my FSRs.
Re: Mini differential IR height sensor board June 22, 2015 06:24PM |
Re: Mini differential IR height sensor board June 28, 2015 07:28PM |
Re: Mini differential IR height sensor board June 29, 2015 06:05AM |
Re: Mini differential IR height sensor board June 29, 2015 02:28PM |
Re: Mini differential IR height sensor board July 15, 2015 07:06PM |
UK EU Rest of world 1 board 27.36 35.27 30.37 2 boards 52.11 60.26 51.30
Re: Mini differential IR height sensor board July 16, 2015 07:50PM |
dc42
On my delta, the reproducibility is generally +/- 1 microstep, which is 12.5um on that machine.
Re: Mini differential IR height sensor board July 17, 2015 08:08AM |
roboprint
dc42
As I can see, you are using usual microswitches at tower endstops. Does the quality of microswitches affects quality of autocalibration using this IR sensor? What is the IR spot size on the bed? As I understand the particles of dust on bed and in the air not affect the quality of calibration?
roboprint
Re: Mini differential IR height sensor board July 24, 2015 10:28AM |
Re: Mini differential IR height sensor board July 25, 2015 05:53PM |
Re: Mini differential IR height sensor board July 25, 2015 07:09PM |
innkeeper
how close can you get with the board and not have temperature issues.
also, what temp is the electrolytic rated for?
Re: Mini differential IR height sensor board July 26, 2015 05:50PM |
Re: Mini differential IR height sensor board July 26, 2015 06:05PM |
frodriguez96
I sent you a PM for a purchase request for one of the new v1.1 boards to US. Just wanted to make sure you reviewed it and maybe if im on a waiting list, would like to know.
Re: Mini differential IR height sensor board July 27, 2015 03:31PM |
Re: Mini differential IR height sensor board July 27, 2015 05:18PM |
Risingphoenix
Just want to say thanks - received one of your new boards (v1.1) and it works really well - finally can use a heated bed
Modified my Kossel J-Head with secondary fan to mount the holder, if anybody is interested: Thingiverse
Re: Mini differential IR height sensor board July 29, 2015 10:05AM |
Re: Mini differential IR height sensor board July 31, 2015 06:46PM |
Re: Mini differential IR height sensor board July 31, 2015 07:16PM |
patrickrio
what is the dimensions of this version of the board? I want to see if it will fit....
Re: Mini differential IR height sensor board August 01, 2015 03:05PM |
Re: Mini differential IR height sensor board August 01, 2015 05:57PM |
Brex480
Defiantly interested in picking one of these up in the future. Will you be continuing to make them?
Re: Mini differential IR height sensor board August 02, 2015 09:15AM |
Re: Mini differential IR height sensor board August 02, 2015 10:21AM |
mdcompositi
can I use it on ramps 1.4?
