Prusa i3 Improved kits for sale at Twelvepro.com
Posted by maxoutny
January 04, 2013 10:53PM
We found latest Prusa i3 printer design, the one Josef Prusa showed at Makerfaire this year in New York, for its elegant simplicity, but hinge like connection between Y axis assembly and frame needed improvement, in our opinion.
Using CAD software we reworked Prusa i3 design:
- Laser cut frame was stiffen by adding two angle members connected to the rear side of Y axis assembly.
- Original, printed Z Axis mounting parts proven to be easy to break, which is why we replaced them with stronger laser cut parts.
- We did not like loose ends on Z Axis lead screw (similar to Printrbot design), therefore we added miniature flanged ball bearing on each side, to support lead screws on the top.
- All printed plastic parts were slightly changed, we felt that we should give them additional strength and better cosmetic appearance.
- Y axis assembly can be removed and installed back in a minute. Convenient for transportation or shipment.
- Dimensions and axis travels of original Prusa i3 preserved.
Test print here:
One of the First Prints
open | download - Prusa i3m - 0.jpg (191.9 KB)
Re: Prusa i3 Improved kits for sale at Twelvepro.com
May 23, 2013 06:29PM
Deleted
Edited 1 time(s). Last edit at 05/23/2013 07:38PM by mxdbag.
