[Germany | EU] MendelMax Kit
Posted by gribble
February 14, 2013 03:29PM
I want to sell my (complete?) MendelMax Kit. I search the BOM and listing of the following sites (some are in german) and ordered the parts from different places a few months back. But unfortunately I don't have the time to complete this project with all the things I have to learn with trial and error. As far as I can judge there is nothing missing to build a MendelMax (except maybe the springs for the heated bed and some screws&nuts). But since I never build a 3d printer I can't give you a guarantee that nothing else is missing. There is also a LCD & SDCard Reader included in this package which are not necessary for a mendelmax build.
[brillenflieger.de]
[wir-bauen-einen-3d-drucker.de]
[mendelmax.com]
[techpaladin.com]
Wade Extruder 3mm 9/47 (komplett) I bought from [reprap-fab.org] with 0,5 und 0,35 nozzle
Plastic set for MendelMax with lower motor mount and RJMP-01-08, also from [reprap-fab.org]
2x tooth belt T5 with Kevlar (90cm X; 120cm Y)
2x Aluminium Pulleys T5/10.
5x ball bearing 608ZZ
12x IGUS RJMP -01-08
1x Mega2560 board rev.3 (100% Arduino-compatible) The mega2560 board is not flashed with any firmware since i don't know which firmware you like to use with it.
1x ramps 1.4
5x A4988 stepper driver
5x heat sink
5x conductive sticker (aluminum)
3x mechanical endstops
1x smart LCD Controller
1x smart adaptor
1x MK2A PCB (still wrapped on the picture)
1x SD Ramps
1x 4GB SD card (genuine Sandisk)
1x 100K ohm EPCOS thermistors
2x cable 50 cm
1x ceramic screwdriver
5x 4 pin cables (motor)
2x 2 pin cables (temperature)
3x 3 pin cables (endstop)
1x 2 pin cables
Single Solid State Relay SSR DC-DC 25A 3-32VDC/5-220VDC
5x Nema 17 Stepper motors
240Watt ( 12V/20A ) PSU
4x extrusion 20x20 I-Typ Nut5 Länge 30cm
4x extrusion 20x20 I-Typ Nut5 Länge 34cm
6x extrusion 20x20 I-Typ Nut5 Länge 42cm
I allready made the holes for the M5 screws at each end. There are also 100 nut screws in this package, look at the later listing here.
2x 40,50cm 8mm smooth rod cf53
2x 42,00cm 8mm smooth rod cf53
2x 44,50cm 8mm smooth rod cf53
2x threaded rod TR8x1,5 IN103 c15
2x threaded rod nut 8,15 SW 17,15
A lot of nuts / screws / washers ...
100x screw DIN912 A2 V2a M 5x10
100x screw DIN912 A2 V2a M 5x16
100x screw DIN912 A2 V2a M 5x25
100x screw DIN912 A2 V2a M 3x10
100x washer Din125 A2 M3
100x washer Din125 A2 M5
100x washer Din9021 A2 M3
100x washer Din9021 A2 M6
100x cylinder head bolt with nut Din84 3x20
25x cylinder head bolt with nut Din84 5x30
10x Din125
2x self tapping nut M8
4x nut M8
5x screw M5x50
4x nut M8
1x screw M8x30
1x screw M8x50
100x nut screw M5 for the extrusion mentioned above
2x 5x8mm CNC Motor Jaw Shaft Coupler 5mm To 8mm
MDF plate 5mm 0,15 x 0,29
MDF plate 5mm 0,25 x 0,29
glas mirrow for the print bead (IKEA Sörli)
2x spring
Stratasys Filament Canister ( [forums.reprap.org] )
I hope I found the correct translations (english isn't my native language) ... if something isn't clear please send me a PM.
I sell the complete package for 650€ (including shipping to germany. contact me for shipping fees to other countries)
greetings
Sven
Re: [Germany | EU] MendelMax Kit
February 17, 2013 12:11PM
Kit is sold. Can't edit or delete my post (or at least I don't know how) sad smiley
February 18, 2013 05:58PM
More Max kits -> reprap.cc smiling smiley))
Sry for advertising winking smiley
