[RRW] Now available: Minitronics €64.99!
Posted by brupje
May 01, 2013 12:46PM
Minitronics is the latest development of ReprapWorld.com. It's designed to be an easy to use, compact and smart solution to fit 90% of the 3D-printers. Unlike the Megatronics, which targets at the advanced range of usages, the Minitronics is plug and plug, which will fit the needs of the average user better.
Minitronics has a powerful Atmega1281 processor with 128 KB memory, running at 16Mhz. The board can be connected to a PC using a normal USB cable. It will register as FTDI FT232R device. The board is compatible with Arduino and will therefor be easily programmed from the Arduino IDE.
Major features
Atmega1281
Powerful Atmega1281 processor with 128 KB memory, running at 16Mhz
Small design
Only 94x57x18mm in size
Thermistors
Two thermistors can be connected
Four MOSFETs
The board has 3 regular MOSFETs (for extruders etc) and one MOSFET for the heated bed (10A) to support
many needs.
Up to 5 stepper drivers with 1/32 step
The Minitronics has four on board stepper drivers. A fifth can be connected externally, using
our External stepper driver board.
[reprapworld.com]
reprapworld.com
PLA, ABS, PETG multiple colors (3 and 1.75 mm) €16,49 / kg
Megatronics 3.0 €79.99 / Minitronics €37,19
Great Job!
