Desktop Reprap 3D printer , based on the TK1 design with Large building size 300mm , low shipping cost to the US.
-Connection parts with high precision aluminium alloy CNC machining ensure stable axis movement and low noise.,
-The machine size 600 * 510 * 610 mm, with big print build size 300 * 300 * 320 mm.
-High rigidity , outside with steel sheet connection, anti frame shaking and reinforce whole inside aluminium alloy extrusion structure.
-The main control board Sanguinololu Ver1.3 a, and the power supply installed in a separate power supply box. With neat wiring.
- with optical coupling isolation for heat bed, avoid big electrical current destroy main control board.
- Dual power supply for safety. 12v,100w power supply for main board ,stepper motor and hotend heating; 24v, 250 or 300 w switch power supply for heating bed which can quickly heat up to 100+ degrees.
-With 10 mm high quality hardened smooth rods for X, Y and Z axis.
- With hotend Budaschnozzle V2.0 upgrade, Sun flower aluminum heat fins, stable and reliable for ABS,PLA filament.
-With high transparent borosilicate glass 300 * 300 * 3 mm for heatbed.
- With high quality HP printer USB cable for communication.
- With micro SD.
- With full graphic LCD control for off-line printer control.
With double Z axis structure, convenient adjustment.
- layer thickness from 0.1 to 0.4 mm.
-Support WinXP, Win7, Win8, Linux, OS.
-Support PrintRun, Slic3r, Cura, Repetier-Host, etc open source software
-Packing with sub-assembly
US$ 1399,- + 220$ Shipping to US (DHL) for other countries please contact us. (special price for reprap.org)
For more info visit our website
http://www.reprapthai.com or send me an PM
Edited 2 time(s). Last edit at 10/12/2013 06:08AM by sascham.
