Anonymous User
The J-Head Lite will blow your face out December 15, 2013 04:06PM |
Re: The J-Head Lite will blow your face out December 15, 2013 06:29PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Anonymous User
Re: The J-Head Lite will blow your face out December 15, 2013 07:02PM |
Re: The J-Head Lite will blow your face out December 16, 2013 01:16AM |
ohioplastics
J-Head Lite
No sugar added!
The main difference in this design is the use of off the shelf products and technology to build a more economical hot end. For example, the heat sink is actually just a simple plumbing cap with a hole through it and mounted with a brass nut. The holder uses 1/2" reprocessed PTFE instead of the 5/8" in regular j-heads. The difference in price between 1/2" and 5/8" is substantial. For 1.75mm filament only.
Anonymous User
Re: The J-Head Lite will blow your face out December 16, 2013 10:28PM |
Re: The J-Head Lite will blow your face out January 09, 2014 10:30AM |
Anonymous User
Re: The J-Head Lite will blow your face out January 09, 2014 09:43PM |
Re: The J-Head Lite will blow your face out January 11, 2014 08:43PM |
Re: The J-Head Lite will blow your face out January 11, 2014 10:28PM |
Re: The J-Head Lite will blow your face out January 12, 2014 10:28PM |
Anonymous User
Re: The J-Head Lite will blow your face out January 13, 2014 11:20PM |
Re: The J-Head Lite will blow your face out January 13, 2014 11:42PM |
Well I bought it because your eBay listing said it would do PLA. I don't currently have any need to print ABS. So I really hope that I don't have any problems. I will be posting back here with a review (good or bad). I have a genuine J-Head and a few other extruders to compare it to.Quote
ohioplastics
I've had alot of complaints with people using it with PLA. I think it has something to do with the steal barrel. I'm working on trying to get the 2mm hole smoother, although I have limited machining capacity.
I'll try another drill bit & we'll see how it goes. @ $13 a drill bit, I'm hesitant to make the leap, but I guess it's gotta be done. I'll send replacement barrels for anyone who is having difficulty with PLA. Just hit me up on Ebay.
Anonymous User
Re: The J-Head Lite will blow your face out January 14, 2014 12:10AM |
Re: The J-Head Lite will blow your face out January 14, 2014 12:19AM |
Re: The J-Head Lite will blow your face out January 14, 2014 03:07PM |
Anonymous User
Re: The J-Head Lite will blow your face out January 14, 2014 05:01PM |
Re: The J-Head Lite will blow your face out January 14, 2014 05:15PM |
Anonymous User
Re: The J-Head Lite will blow your face out January 14, 2014 05:25PM |
Re: The J-Head Lite will blow your face out January 14, 2014 11:47PM |
Re: The J-Head Lite will blow your face out January 15, 2014 01:08PM |
Anonymous User
Re: The J-Head Lite will blow your face out January 15, 2014 02:09PM |
Re: The J-Head Lite will blow your face out January 16, 2014 01:25PM |
Anonymous User
Re: The J-Head Lite will blow your face out January 16, 2014 04:40PM |
Re: The J-Head Lite will blow your face out January 17, 2014 09:34PM |
Re: The J-Head Lite will blow your face out January 18, 2014 09:48AM |
Could you run some PLA and let us all know how it comes out?Quote
ohioplastics
I picked up some ajax and some pipe cleaners today. Polished a couple with a power drill. They look really shiny! Whether or not it helps PLA extrusion, couldn't say, but at least I'll sleep better knowing that the inside of my tubes are polished. There could be 50 things that can cause a hot end to jam. The tubes are just my best guess. I'm skeptical that it really makes that big of a difference, but what do I know.
Anonymous User
Re: The J-Head Lite will blow your face out January 18, 2014 02:58PM |
Re: The J-Head Lite will blow your face out January 21, 2014 09:24AM |
Re: The J-Head Lite will blow your face out January 21, 2014 11:06AM |
Anonymous User
Re: The J-Head Lite will blow your face out January 21, 2014 04:09PM |
Re: The J-Head Lite will blow your face out January 22, 2014 07:52AM |
