Super configuration, specialized export , own factory, accept OEM/ODM
Specification[/size]
Tech print[/color]: FDM (Fused Deposition Modeling)
Print size: 200*200*180mm
Max resolution/height accuracy: 0.1mm-0.4mm
XY axis positioning accuracy: 0.012mm
Nozzle diameter:0.4mm
Input voltage:100V-240V
Working voltage:12V
Size:
Machine dimension:450*460*360mm
Package dimension:470*470*330mm
Export dimension:480*480*270mm
Product weight: 7.8kg
Packing weight: 9.8kg
Hardware Configuration
Subject Structure: acrylic laser cutting device
XY axis drive: 45# carbon steel optical axis
Z axis drive: integrated four wire screw motor
Stepper motor:step angle 1.8 degree, 47mm motor
Extruder: newest upgrading MK8 double cooling technique
Software:
Compatible software: Cura, Slic3r
File format: STL, G-code
OS: Windows XP, Windows 7, Mac OS X
Printing Consumables
Printing Material : PLA/ ABS
Material Diameter: 1.75mm
Color: over 10 colors or custom-made color
i3 three features
Standard Industrial-strength:With MK8 extruder,you cost a toy but gain the super accuracy no less high-end import printer.
No Plugging: 0.4mm electroplating work with polishing&grinding, the nozzle temperature far more stable than ever before
Adjustable printing speed: debugging the printing speed at any time even to 200% speed.
Well-designed by Shenzhen Eternal Feat Co.,Ltd engineers, Migbot i3, the only core accessories, using industrial equipment with reasonable price, compared with DIY printer on the market. Every detail being strictly selected, making sure I3 posses high efficiency and stable performance.
acrylic surface
Thickened acrylic laser cutting device made Migbot I3 more stable when running in high speed. Well-formed appearance, custom-made color is your optimal choice.
main board
Customized by domestic famous main board factory in melzi 2.0 version, our main control IC takes brandy new original ATMEGA1284 with G code TF card slot. It is the best choice to print offline without additional LCD.
motor
47mm lengthen stepping motor with 1.8 degree step angle, larger torque than 40mm and 33mm motor, ensure right running with high speed synchronously.
optic axis & screw
As abrasive resistance and smooth it is,optic axis takes 45# carbon steel harden with quenching process.
Four-wire T-type screw, special-made in large manufactory by Changzhou, Jiangsu province , guarantee the precision of X axis drive.
Printing Platform
The upgrading heating platform balanced the heating surface. Meanwhile, anodizing surface producing tough protective layer on the aluminum alloy, strengthen the abrasive resistance and working life extraordinarily.
Bearing& Belt
Stability far more than common bearing with ribbon, Migbot i3 adopts SC8UU and lengthen SC8LUU linear bearings which make our products super quality in the details.
Common Products on the market
√ Industrial-strength MK8 extruder, dual radiator fans, special processing nozzle inwall without plugging.
× Single fan + one straight pipe with nozzle = simple structure
√ $3 SC8LUU linear bearing on X, Y axis drive, Migbot i3 increases the accuracy of location greatly through anodizing.
× Only $0.3 bearing + $0.001 bandages. Just can do if you bind tightly.
√ Special-made four-wire T-type screw drive +0.1mm range location accuracy. Just two Z axises cost more than $30. Any cheaper supplier, please contact us~!
× Common Z axis screw($1.2) + coupling drive=unstable quality products. Anyone who wants the cheaper screw, contact us,too!
√ Original Omron EE-SP X403 made in Japan , more precision than ever before.
× ordinary touching limit switch = slight movement + adjust the height of the platform frequently.
Why Choose Us?
1.Direct manufactory supply
The biggest professional 3D printer factory in Shenzhen, providing various rapid prototyping of 3D printing programs. We supply original owner service like OEM/ODM.
We are always here waiting for your coming no matter you want retailing or wholesaling, domestic sale or foreign trade, bidding or OEM~!
2. Full-scale after-sale service
Returns on unused items within 7 days
Free replacement during warranty within 6 months
Free technique maintenance within 3 years
Technical consultation life-long
3、Considerate pre-sale service
We sincerely invite you to visit our factory and learn basic training. Or we can print products you send beforehand. What’s more? We provide full-scale after-sale technical service and training service to our agents!
24-hour service hotline: 400 650 3501
Address:East Zone No.1, Shangxue Industrial Area, Longgang District, Shenzhen City, China.
Tel:+86-0755-66605832, 18507553919
Email:
[email protected]
Skype:migbot-alisa
[/s][/s][/sup]
