Re: Mini differential IR height sensor board April 05, 2018 08:31PM |
Re: Mini differential IR height sensor board April 07, 2018 10:27AM |
Re: Mini differential IR height sensor board April 07, 2018 12:31PM |
Re: Mini differential IR height sensor board April 08, 2018 06:59AM |
Re: Mini differential IR height sensor board April 09, 2018 08:54AM |
dc42
I can't be completely sure because the focus of the shot from underneath isn't great, but I think that the edge of the fan duct with the cutout in it for the capacitor isn't sufficiently clear of the IR LEDs and phototransistor.
Re: Mini differential IR height sensor board April 10, 2018 03:59PM |
Re: Mini differential IR height sensor board April 10, 2018 04:46PM |
Re: Mini differential IR height sensor board April 30, 2018 10:15PM |
Re: Mini differential IR height sensor board May 01, 2018 01:26PM |
Re: Mini differential IR height sensor board May 02, 2018 08:56AM |
Re: Mini differential IR height sensor board May 30, 2018 04:40PM |
Re: Mini differential IR height sensor board May 31, 2018 04:58AM |
Re: Mini differential IR height sensor board June 13, 2018 03:51PM |
Re: Mini differential IR height sensor board June 13, 2018 06:38PM |
JKaechler
I had some trouble with the IR sensor back when i was running plain glass over an aluminum heatbed. Now I am running borosilicate glass 1/4" thick, and i have a proper ramps/marlin board running now..... so i have a question. Would it help or hurt to sand the top surface of that boro glass to make it sort of opaque. would the ir reflect better off it? sanding with something really fine like 220 grit, and an orbital electric sander.
Re: Mini differential IR height sensor board June 13, 2018 11:08PM |
Re: Mini differential IR height sensor board January 20, 2019 01:18AM |
Re: Mini differential IR height sensor board January 21, 2019 08:16PM |
Re: Mini differential IR height sensor board January 22, 2019 02:58AM |
Re: Mini differential IR height sensor board January 22, 2019 08:42AM |
Re: Mini differential IR height sensor board May 08, 2023 08:33AM |
Re: Mini differential IR height sensor board May 08, 2023 11:59AM |
Re: Mini differential IR height sensor board May 08, 2023 03:14PM |
dc42
If the sensor doesn't detect a pullup resistor to +3.3V or +5V then it operates in pseudo-analog mode, outputting 4 different voltages depending on whether it is a long way from the bed, close to the bed but not quite triggered, close enough to be triggered, or overloaded with ambient light. If the board it is connected to treats the input as digital then it might see the "close to the bed but not quite triggered" as triggered. So maybe you just need to enable the pullup resistor on the input of the board that it is connected to.
Re: Mini differential IR height sensor board May 08, 2023 04:03PM |
Re: Mini differential IR height sensor board May 08, 2023 07:04PM |
dc42
You can tell whether the sensor has started up in analog or digital mode by counting the number of LED flashes after power up. See the instructions at [miscsolutions.wordpress.com].
Re: Mini differential IR height sensor board May 09, 2023 03:28AM |
Re: Mini differential IR height sensor board May 09, 2023 07:39AM |
