3DMarkt
Wanhao Duplicator 4S
2015 upgrade - New MK10 extruder
2 Free spools in the box
Dual Extruder
Heated Bed
1 year warranty and European Service
Introducing the latest addition of the Duplicator 4 series, the Duplicator 4S. Through its explicit structure and technological upgrade, the Duplicator 4S is a one of a kind 3D Printer, which combines efficiency and top quality to ensure the ultimate 3D printing experience. Equipped with the new MK10 Dual-Extruder, the Duplicator 4S contains all the extra benefits of the Duplicator 4x along with new technological enhancements. Features include a heated build plate and fully enclosed build area which prevents shrinking and warping of plastics and allows good quality products to be printed every time. Its modern black steel exoframe allows the printer to triumph in the production of flawless goods and keeps it stable and safe from vibrations. This brand new model is also fitted with a 1/16 micro-stepping motor control which enhances the electronics efficiency. ReplicatorG is included in the package, however, you can also use other software like Makerbot Desktop.
Features:
• Extruder: New! MK10 Dual-Extruders
• Filament Size: 1.75mm Dedicated
• Layer Capability: 0.1mm - 0.5mm
• Build Envelope: 225mm x 145mm x 150mm
• Filament Capabilities: ABS, PLA, PVA, NYLON, HIPS and other common filaments.
• Software: ReplicatorG (Opensource) included – other software possible
• Warranty: 1 Year Limited Warranty
• Frame Colour: Black Steel Exoframe
• Heated build plate
Specification
Print Technology FFF Fused Filament Fabrication
Interface Print with SD Card or direct via USB Port
Max Printing Object Size/
Build Volume 225 * 145 * 150mm, about 5 l
Layer Resolution 0.1mm -0.5mm (100 micron)
Nozzle Diameter 0.4 mm
Positioning Precision Z-Axis 2.5 micron, XY Axis 11 micron
LCD display 4x20 LCD character display and multi-direction control pad
Printing Object Specification
Position resolution 0.1mm
Layer thickness 0.1mm - 0.5mm (100 micron)
Extrusion temperature Recommended Maximum 230 C
Platform temperature Heated Build Platform 120 C Maximum
Temperature Sensor Thermocouple temperature sensors
Vertical Printing Speed 15 Cubic Centimetre/Hour
Software
Replicator G Linux, OSX and Windows
Input File Type STL and G-Code
(Other compatible software like Makerware also works)
Filament Support
Material Type Prints ABS, PLA, PET, Nylon, Laywoo-D3, LayBrick, BendLay
Color Wanhao PLA & ABS over 43 colours to choose from
Filament size 1.75+-0.1mm
Components Specification
Chassis Black Steel Exo-frame, very stable and durable
Build platform Heated build plate made of aluminum
Stepper Motors 1.8° step angle with 1/16 micro-stepping
XYZ Bearings Wear-resistant, oil-infused bronze
Max temperature 260°C(500°F)
Connectivity USB, SD Card slot
Printer Dimension 320 x 466 x 382 mm
Printer Weight 12 KG
Electric Power Supply 220V / 110V (Universal power supply, take IEC cable)
Output 200 W
Compliance GB, CE
Warranty
12 Months warranty - (Normal wearing and consumables not covered).We will provide parts or service on items that proved to be defective.
What´s in the box
• Wanhao Duplicator 4S 3D-Printer
• 2 free spools of filament, 1 kg each
• SD Card
• Acrylic cover
• Power cord
• USB cabel
• 3M Tape
• Glass plate with clips
• Filament guide Tube
• Spool holder
For more information check our our website www.3DMarkt.at
The following product can also be found on ebay [www.ebay.com]
You can also Find us on Facebook [www.facebook.com]
Edited 1 time(s). Last edit at 08/24/2015 08:15AM by 3DMarkt.
