This machine can be bought here: [botmill.com] <-- with Motors and Electronics
or
Here: [botmill.com] <-- without Motors and Electronics.
This RepRap Mendel is distributed exclusively through BotMill and comes fully assembled with very minimal work required.
Details:
* Original Mendel solidedge files used to produce RP parts on commercial FDM machines for a perfect look and fit. No drilling/reaming/sanding/grinding required.
* Available in colors, Lemon Yellow, Fluorecent Red, Bright Blue, and Black.
* Plastic parts for Adrian's geareded extruder included(extruder assembly required)
* Latest Extruder parts! (Nichrome wire, nozzle, PTFE, PEEK, M4 insert and metal parts) [
reprap.org]
* PCB thin sheet parts are made of 6mm cast acrylic.
* Table and Y spyder are made of T6 6061 Aluminum
* All hardware including extras of each.
* Full bearing kit
* Vertex threaded rod and hardware are zinc plated
* Threaded SS rods, with TIG welded nut for ZERO slip when used with our captured Z axis pullies.
* Captured Z axis pullies to give required clearance under the machine and ZERO slip. [
www.thingiverse.com]
* Precision ground round bars made from tooling steel for X, Y and Z axis.
* Nopeheads gears with set screws
* Belts for X, Y and Z axis
* 10ml bottle of red LOCKTITE 262/ Threadlocker
Note: Electronics, Temperature sensor, Kapton tape and/or the fire cement for holding the nichrome wire to the tip is not included.
This Machine also includes:
TechZone electronics kit with power supply and motors as seen here
Electronics Kit with Power Supply and Motors.
Please note that the electronics kit, power supply and motors need to be attached to the assembled frame manually.
Package weight and dimensions when shipped:
22LB's & 22 x 22 x 30"H
Lead time on this product is typically 3-5 days after the order is placed.
This kit is not produced by Techzone, but electronics are being bundled by Botmill
Edited 1 time(s). Last edit at 09/14/2010 01:55PM by BotMill.
