RepRapPro spares available January 15, 2016 06:16PM |
Re: RepRapPro spares available January 25, 2016 02:18PM |
Re: RepRapPro spares available January 25, 2016 05:00PM |
Re: RepRapPro spares available January 26, 2016 09:46AM |
Re: RepRapPro spares available January 26, 2016 01:10PM |
Re: RepRapPro spares available January 26, 2016 04:29PM |
steve0-uk
Hi Jean-Marc
perfect...
more requests if I may...
any of the .5mm one piece nozzles?
also, the mxl belts as used on the Ormerod 2
thanks
Steve
Re: RepRapPro spares available January 27, 2016 11:33AM |
orictosh
I have one MXL belt (used on the Ormerod 2) for the X axis (cut to size 710mm) [www.3dprintandstuff.co.uk]
Also have details of a UK based supplier so wouldn't take long to get some more.
Chris Hills
Re: RepRapPro spares available January 27, 2016 12:02PM |
steve0-uk
orictosh
Chris Hills
Hi Chris
thanks for the offer, but I need a few mtrs of it
Re: RepRapPro spares available January 27, 2016 03:37PM |
Re: RepRapPro spares available January 29, 2016 03:23PM |
Re: RepRapPro spares available February 03, 2016 11:41AM |
Re: RepRapPro spares available February 04, 2016 05:56AM |
dave239
Hello Jean-Marc
I have just seen this topic and have found several Ormerod2 (FIRST batch 528.0) items that I need, already listed.
Before I place my order, please can you tell me if there are any of the following still available:
Main Duet board
0.5 mm one piece nozzle
Proximity sensor (4 wire) alone ( i.e. without lead)
Revised Ormerod 2 heated bed pcb with the spade power connections as at 528.4 ( I had to upgrade to this bed following a pcb fire !! )
Heated bed bead thermistor
dave239
Also can you confirm that the 3mm PTFE tube that guides the filament into the extruder is the same as that used to line the one piece nozzle ? - and do you have any of it ?
Re: RepRapPro spares available February 04, 2016 07:04AM |
Re: RepRapPro spares available February 04, 2016 07:27PM |
orictosh
The tube that goes from the extruder drive to the hot end is 4mm PTFE when using the quick-set nozzle, supplied in the kits, it screws straight in cutting it's own thread.
The 3mm tube goes from the extruder drive back towards the filament reel.
Chris
Re: RepRapPro spares available February 04, 2016 07:29PM |
jmgiacalone
Hello dave239,
I have all the parts you listed except for the heatbed PCB. Actually I do have some but their resistance is only 0.9 Ohm so they would draw too much current.
If you send me an email to jeanmarc@emaker.limited I can send you back a price for the lot.
Thanks,
Jean-Marc.
Re: RepRapPro spares available February 05, 2016 02:53AM |
dave239
orictosh
Chris
Hello Chris
Thank you for your reply.
I understand exactly what you have explained. My query is slightly more complicated as my Ormerod2 was one from the very first batch which did not have the quickset hot end.
- so I was trying to confirm that the 3mm PTFE liner, that is required for the original hot end "one piece nozzle", was indeed the same as the 3mm PTFE tube that runs from the filament reel to the extruder.
Thank you
David
Re: RepRapPro spares available February 07, 2016 01:22PM |
orictosh
Yes, I would say it's the same diameter as the one that runs from the filament reel to the extruder. I upgraded from a Single nozzle "one piece" it's thread runs it's complete length to having 2 hot-ends which use the newer quick-set nozzle; Also using this nozzle with a duet shield makes it possible to use the paste extruder that was designed before RRP Close
Re: RepRapPro spares available February 16, 2016 01:10PM |
Re: RepRapPro spares available March 15, 2016 02:36AM |
Re: RepRapPro spares available March 15, 2016 05:06AM |
Re: RepRapPro spares available March 16, 2016 02:13AM |
Re: RepRapPro spares available April 01, 2016 09:32AM |
