Print virtually anything you want with the Flying Bear 3D printer – your imagination’s the limit! Not only can it print faster than the Makerbot, but thanks to it’s 3 cooling fans it can keep printing for longer, too
Built upon a stylish aluminum frame, the Flying Bear printer won’t let you down. It’s sturdy construction is just a small part of the picture…
Who's it for?
The Flying Bear is for virtually anyone interested in 3D printing. Whether you’re a hobbyist looking to create a thoughtful birthday present or you need a machine in the lab to create precision parts, look no further than Flying Bear.
Machine Features:
Machine has the same structure as the Makerbot,running faster and has less noise.
Model Number:Flyingbear-P902
The print size of our machine is 220*220*280.
Detailed Video of installation has been included
Installation is easy to set up as some of the parts are already assembled
Double fan design full aluminum Extruder.
250W 20A High power supply influence heating process quicker and the printing quality is better
Mainboard, the extruder, the model all equipped with cooling fans, which allows the printer to print for a long time.This is not available in the general printer!!
Three fan cooling system prints perfectly without any block or deforming
The mainboard cooling fan can guarantee long uninterruptred work(longevity)
No Acrylic,No Woods All the machine parts are of Aluminium material and high precision injected molded parts for greater stability
Cable alignments are properly managed for better appearance
Technical Parameters:
Name :Flyingbear 3D Printer kit
Print size: 220 X 220 X 280mm.
Layer Thickness of 0.05mm.
MAX printing speed: 150 mm/s.
Material type: PLA, ABS, PETG, Wood, PVA, Flexible Filaments .
Material specifications :1.75mm in diameter.
Positioning accuracy: Z 0.004mm, XY 0.012mm.
Nozzle diameter: 0.4mm (customized 0.2mm/0.3mm).
Recommended extruder temperature: 210°C (the maximum 260°C).
Hot bed temperature: 60-110°C .
Best ambient temperature: ≥25°C.
Power requirements: 110V/220V, 250W, 50Hz, 0.89A.
Connection: SD card or USB.
The file print format: STL,G-Code.
Compatibility: Windows, Mac.
Slicing software: repetier-host,Cura.
Machine weight: 10kg
Flying Bear Box Includes:
One Spool of Filament
Extra 0.3 Nozzle
8GB SD Card
Tool set
Small Shovel
Shop : [
www.3dprintersbay.com]
