[US-Los Angeles] Free prusa mendel hardware, printed parts, j-head hot ends, filament. local pickup only
Posted by John Meacham
Everything in picture is free for local pickup in santa monica except the motor attached to the extruder which is $10 if you want it. (but the extruder and hot end is free.)
whoever takes it _must_ take everything, my only request is if you don't use it all, give what you don't a good home rather than dumping it.
This is NOT a complete printer and is missing a few hardware bits, but has what is left over after scavaging parts for a new printer from my old prusa mendel.
included is:
most prusa mendel hardware, prusa mendel printed parts , a combination of v1 and v2 parts along with various thingiverse updates. aluminum base plate with linear bearings attached.
bearings, linear and other. belts.
2 original j-head hot ends including PEEK barriers machined by the inventor, one groovemount, the other mounted via grub screws.
extruder/hot-end needs some work as it has warped and is clogged, you may need to print a new x carriage out of something that can handle heat better than PLA or machine something.
2 rolls of filament included. 5kg of 3mm natural PLA and 1kg of green ABS.
All filament and extruders are 3mm.
taker must take it all.
John
open | download - out.jpg (144.9 KB)
Are the Z motors $10 too?
