Wanhao Duplicator 7 UV Resin DLP 3D Printer
Posted by 3dprintersbay
March 06, 2017 04:23AM
Wanhao Duplicator 7 DLP SLA 3D Printer DUP (Direct UV Printing)
Ships Worldwide direct from Wanhao
The Wanhao Duplicator 7 DLP is a resin desktop 3D printer made by Wanhao.Duplicator 7 has a build area of 120x70x200mm and a layer resolution capability of 35 microns
The Wanhao Duplicator 7 DLP uses the vat photopolymerisation 3D printing technology. DLP stands for Digital Light Processing. For 3D printing the Wanhao Duplicator 7 DLP selectively cures liquid resin layer after layer in order to build an object. It uses the 395-405 nm wavelength and is compatible with most of the resin materials available on the market.
The Wanhao Duplicator 7 DLP is equipped with a HD LCD screen which offers a 2560 x 1440 pixels resolution. The input is HDMI type. This 3D printer offers a build speed of 15mm-35 mm/Hour.
The Wanhao Duplicator 7 DLP uses the Creation Workshop software to slice and control the printing process.
Specifications:
Printing Technology UV Resin DLP 3D Printer
Max Printing speed 30mm/hour
Max Printable Area 120*68*200mm(L*W*H)
Resin Type 405nm UV Resin
Software Creation Workshop
Resolution 2560*1440
Accuracy Z: 0.004MM
Layer Thickness 0.035~0.5mm
Weight 12 Kg
Earliest Shipping Date March 7th - March 14th 2017
https://www.3dprintersbay.com/wanhao-duplicator-7-sla-3d-printer
