$344 Cheapest Reliable Dual extruder Assembled 3D Printer smiling smiley
Posted by Angeline
March 09, 2017 06:30AM
Till now people are enjoying building 3d printer kit. But if incase you are planning to get a professional assembled 3d printer that print right out of the box. Then this one definately for you !
This printer is personally Assessed, Tried & Tested by our Engineers at manufacturer site.
Dual extruder always fascinate Designer, Artists, 3d modellers as they're keen into making multi colored models and thier model size fall in between 200x200x200mm range. Currently Makerbot,FLASHFORGE and its Clone "QIDI TECH" are most prevailing in Dual extruder 3d printer segment but print area is quite smaller 145x150x200mm.
$344 "LEADER 200" Dual Extruder is an Assembled LARGE format 3d printer 210x210x280mm print size. It has lookalike resemlance of MALYAN 200 but have print area benefit over it. Its compact design, Aluminium frame body, High Stability, Reliability, wide range filament compatibility makes this printer stand out of the crowd.
This VIDEO DEMONSTRATE its unboxing, working and print quality.
here are some more images of printer:
3D Printed Model Images
It not just end there, 12 months warranty period and life time technical support are offered with this printer
Edited 2 time(s). Last edit at 03/09/2017 06:34AM by Angeline.
