FlyingBear TORNADO Full Metal DIY 3D Printer Kit - 3DPRINTERSBAY
FlyingBear Tornado Highlights:
Each part is made of metal! the structure and the extruders are all-metal!
Using linear guide rail as motion mechanism, so it runs smoothly and the noise almost can not be heard.
Sheet metal housings are provided with a variety of mounting holes that allow you to modify the printer.
With the rare 10mm wide synchronous belt, the printing accuracy is higher.
The head of 3D printer can be disassembled separately, so the installation and maintenance are very convenient.
Hot bed supported by double Z axis design, so in the process of printing, the hot bed more will be smooth and steady.
There are many types of printers available, dual extruders, single extruder, automatic leveling, and so on. You can meet all of your requirements here!
Independent Dual Extruders : Two separate extruders that can print the same product at the same time and have an automatic leveling function
Technical specifications:
Name :Flyingbear - Tornado 3D Printer Kit
Print szie:350*300*300mm
Printer szie:545*485*485mm
Layer thickness precision: 0.05-0.3
MAX printing speed: 150 mm/s.
Material type: PLA, ABS, PETG, Wood, PVA, Flexible Filaments .
Material specifications :1.75mm in diameter.
Positioning accuracy: Z 0.002mm, XY 0.01mm.
Nozzle diameter: 0.4mm (customized 0.2mm/0.3mm)
Recommended extruder temperature: 210°C (the maximum 240°C).Hot bed temperature: 60-120°C .
Extruder number: 1/2/Independent Dual Extruder (IDEX).
Power requirements: 110V/220V, 450W
Connection: SD card or USB.
The file print format: STL,G-Code.
Compatibility: Windows, Mac.
Control software: Repetier-host,Cura.
Machine weight: 20kg.
LEARN MORE
Edited 1 time(s). Last edit at 06/28/2017 11:20PM by 3dprintersbay.
