US SELLER Smooth X Axis Ends Assembly with Belt Tensioner ORANGE
Posted by Fiyero88
July 16, 2018 09:00PM
US SELLER FAST SHIPPING!
I had these professionally printed through 3D Hub. They are a matching set made from thick ABS Orange. They are based off the design at [www.thingiverse.com]
These never got used past me assembling them so Im selling them as new other. Comes with X axis motor mount, X axis Idler Pulley with 16T pulley included, X axis belt tensioner(works by tightening the screw with a screw driver) x axis limit switch assembly with micro limit switch(I hand soldered the wires) to the switch the insides of the ends come with Ingus Drylin Bearings two each for a total of four.
This will work with any 3D printer not just Prusa as long as the smooth rod spacing is 45mm which is the spacing on these. Also has pre drilled holes for leads crew also make sure the spacing on your printers z axis smooth rod and lead screw is 17mm this is what these are designed for(most common spacing)
As always shipping is free!
Link goes to the eBay auction where these are up for grabs:
X Axis Ends
