32-bit 48Mhz controller board, 45€ incl VAT!
Posted by brupje
November 07, 2018 07:59AM
New and improved: Minitronics 2.0! 32-bit board running at 48Mhz, for only €45 including VAT!
Compact, affordable, single-board solution with on-board stepper drivers. 32-bit SAMD21 Microprocessor running at 40Mhz, well capable of running even Delta printers at decent speeds.
Minitronics is the slim but powerful electronics line. It's designed to be an easy to use, compact and smart solution to fit 90% of the 3D-printers. Unlike the Megatronics, which targets at the advanced range of usages, the Minitronics is plug and play, which will fit the needs of the average user better.
Minitronics has a powerful SAMD21J18 32-bit microprocessor with 256KB memory, running at 48Mhz. The board can be connected to a PC using a normal USB cable and can run stand-alone from 12V power supply. The board is compatible with Arduino and will therefor be easily programmed from the Arduino IDE.
[reprapworld.com]
Edited 1 time(s). Last edit at 11/07/2018 07:59AM by brupje.
reprapworld.com
PLA, ABS, PETG multiple colors (3 and 1.75 mm) €16,49 / kg
Megatronics 3.0 €79.99 / Minitronics €37,19
