The J-Head 12 HiFlow Has Been Released! December 24, 2018 11:05AM |
Re: The J-Head 12 HiFlow Has Been Released! December 26, 2018 10:51PM |
Re: The J-Head 12 HiFlow Has Been Released! December 27, 2018 02:21AM |
Re: The J-Head 12 HiFlow Has Been Released! December 27, 2018 07:47AM |
Re: The J-Head 12 HiFlow Has Been Released! December 27, 2018 12:04PM |
Re: The J-Head 12 HiFlow Has Been Released! December 27, 2018 12:05PM |
o_lampe
It's pretty slim! Perfect for tool changing.
The heatsink looks, like it would work with remote cooling. Just aim a stream of air to the bottom of the heatsink.
Do you have plans for a watercooling jacket?
Re: The J-Head 12 HiFlow Has Been Released! December 27, 2018 12:08PM |
Ed3D
Nice! I like.
I would love to see some thermal camera pictures of it!
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 02:45AM |
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 08:56AM |
o_lampe
Will we get silicone socks for the heaterblock?
I imagine a bit more parasitic heat transfer compared to 'other' hotends, because of the smaller gap between heaterblock and the alu-parts.
Do you use common nozzles?
Are they replaceable? I guess, I have to replace the whole heaterblock?
If it will fit Duet3D's Smart Effector, I'd give it a try.
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 10:03AM |
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 10:28AM |
warbunniex
So you said it can "thread it directly into a mounting hole" would it possibly work with the smart effector by duet?
if so im sold. its got a lot of properties of the hotend i was designing. not perfect, ill still probably make my own. but id definitely like this design.
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 02:59PM |
reifsnyderb
We haven't seen a need for a silicone sock as the brass heater block used in the J-Head 12 HiFlow maintains a very stable temperature.
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 03:34PM |
dc42
reifsnyderb
One thing we've noticed with E3D hot ends is that some users have print cooling fans that blow air on the heater block as well as on the print, and some prints "reflect" the print cooling air on to the heater block. This can cause a sudden temperature drop when the cooling fan is turned on, which can trigger the thermal protection. A silicone sock shields the heater block from this cooling air and mitigates the problem.
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 04:32PM |
dc42
reifsnyderb
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 05:08PM |
Re: The J-Head 12 HiFlow Has Been Released! December 28, 2018 10:34PM |
NitroFreak
I don´t mean to sound mean, but.
I think your "marketing" department has to backthrottle a little with the absolutist statements and exaggerations.
snip
Thanks
Max
Re: The J-Head 12 HiFlow Has Been Released! December 29, 2018 11:35AM |
reifsnyderb
Hello,
Thank you for correcting our cross sectional area measurements. It is an area and should have been listed in mm squared. We have fixed this on the site.
I was going to research your other complaints but stopped as many of your comparisons are unrelated. For example, the "Cube Pro" hot-end information specifically states it is "Not for use with ABS, PLA or Nylon material." The J-Head 12 is for those materials.
Best Regards,
Brian
Re: The J-Head 12 HiFlow Has Been Released! December 29, 2018 11:40AM |
NitroFreak
Hi Brian,
... snip.....
Thanks
Max
Re: The J-Head 12 HiFlow Has Been Released! December 29, 2018 12:16PM |
Re: The J-Head 12 HiFlow Has Been Released! December 29, 2018 01:22PM |
reifsnyderb
Hello,
Here's the website where the "Cube Pro" is sold: [www.3dsystems.com]
Best Regards,
Brian
NitroFreak
Hi Brian,
... snip.....
Thanks
Max
Re: The J-Head 12 HiFlow Has Been Released! November 09, 2019 06:20AM |
MKSA
Anyway, because of that, I made my own, all metal too,using a horizontal heatsink, 1cm thick 5cmX2.5cm is enough, from hobbed gear to cold/hot transition zone, 22mm.
