Test print Help needed
May 02, 2010 12:55PM
Hi, Need someone to run a couple of test prints for me....tried to upload to thingverse it has "issues".
A: Two STL files Lens Cap per pic
B: Case Tube STL
1) Don't have a working RepRap
2) Not sure what STL output is exporting
3) NEED SOMEONE TO PRINT OUT & give measure, so I can update the design and put in the public the release!
Thx
open | download - LensCap.zip (2.5 KB)
open | download - case.zip (4.1 KB)
open | download - LensCapCropped.PNG (29.1 KB)
open | download - TestCase.PNG (84.8 KB)
Re: Test print Help needed
May 02, 2010 03:36PM
meassure what?
If a printer is properly calibrated the printed model will match exactly the model.
Sizes, hole-diameters and everything.
LensCapCropped looks like it has a very small overhang of 90°. The maximum that is possible is 60°. Printers cannot print layers in mid-air.
Is test-case a massive, non-hollow cylinder? What needs to be tested in printing a cylinder?
* homeprototype free 3d design repository
* Blog
* Google+
May 02, 2010 03:58PM
MarcusWolschon Wrote:
> meassure what?
Need to account for shrinkage etc.
The case should be more complex than that....several internal threads etc were designed into it and a couple of other tricks in the design.
This will be of the most help..[www.thingiverse.com]
Edited 1 time(s). Last edit at 05/02/2010 04:08PM by Prober.
open | download - TestPrint.png (114.5 KB)
May 03, 2010 12:21PM
Calibration accounts for shrinkage.
That´s why you calibrate the "strech"-settings
after you are done with "perimeter width over thickness".
Even so meassurements on a test-print are only
valid for that one printer, one material,
one environmental conditions, one version of
skeinforge and one skeinforge-profile.
* Blog
* Google+
May 03, 2010 01:56PM
> thickness".
smileys with beer Yes, we are on the same page with this. The test print design needs some adj then a release, followed by the final product.
Thanks thumbs up
