Wanted - Z drive pulley
Posted by reece.arnott
February 09, 2008 09:07PM
Aaaarrrrgggghhhh!
I just snapped my Z drive pulley in half while trying to adjust my Z axis belting!
Does anyone happen to have a spare?
Vik, could you print me one off and send it to me?
I have not had a good weekend, more issues than usual. I got the X axis belting on and working, then when I got the Z axis belting on I found it wouldn't move. It also juddered things so much that the next time I turned it on I had issues with one of the Rx/Tx wires, but which one? I set that aside and got on and did the Y axis belting. Pushing it by hand it works fine.
I think I found the dodgy wiring so I went on to try and find the issue with the Z axis belting sticking. Thats when I snapped it.
Could superglue make it more fragile?
I guess I'm now going to have to find something to dissolve the superglue from the stump I've got attached to the Z drive motor.
Yes, that was a bit of rant but I'm a little frustrated with being so close to having a working Darwin!
Re: Wanted - Z drive pulley
February 10, 2008 03:08AM
If it is a clean break try to super glue the parts back together it seems to make a very strong bond as the surface area and contact between the parts is good
Ian
[www.bitsfrombytes.com]
February 10, 2008 10:34PM
Thats my backup plan :-)
The superglue also came unstuck in the juddering process and I'd just reglued it all when I ran into issues so I'd rather have a new part if someone has one spare. I'll superglue the old one back together anyway though.
February 11, 2008 04:56AM
What about using a dowel or suchlike as reinforcement?
July 24, 2008 09:54AM
I think if you were to put dowels in, they would need to be metal and you'd need several spaced equally around the part.
I don't know the strength of the material you're using but I'd expect it to break again from the tension in the belt.
