1X2
Release status: unknown
Description | Perky Wooden RepStrap
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Description:
The 1X2 is a Reprap class 3D-printer that can be built with access to only a drill-press and hand-saw. All the parts can be made with one-dimensional tools and straight cuts.
mrkimrobotics.com
Status Summary:
Working Status:
The 608 linear bearing system works well and is mature.
The shaft-couplers work well.
The 1X2 vertex frame system has worked well.
The Scoop Extruder has printed for hours continuously with no issue.
Experimental Status:
Countering "belt creep" with non-slipping elastic belts in open-loop control as a function of speed remains an issue of study.
Features:
- It has a printable area greater than all of its parts(including the rods).
- Dual-head extruder and plotter(w/ hot and cold separation).
- Simultaneous extrusion and plotting.
- Quick-change plotter head.
- Narrow x-carriage design.
- It uses only 608 bearings.
- It uses only 5/16" bolts.
- It uses all 1-unit length rods.
- It uses all DIY belts.
- Uses all DIY drive pulleys.
- Uses all DIY couplers.
- Full conveyor-belt y-axis(reduced parts, high accuracy, low weight, automated ejection, large build area).
- Adjustable conveyor belt tension with bed height.
- Conveyor-belt goes to both edges of the machine for end-to-end chaining of machines.
- Hand-crank for conveyor belt.
- A single block is capable of building all frame vertex points.
- A single extended block is used for Nema17 motor mounts, 608 bearing axle supports and pillow-blocks.
- The 5/16" holes fit both 8mm & 5/16" hardware.
- Works with variable lengths. The design is not length specific, so you can build a range of
- machine sizes, from full size to compact with the same pieces.
- The frame is chainable, you can build a linked multiple segment Longcat machine.
- It uses only 1"x2" wood for all parts.
- It uses a 35/77 system, where all the parts are either 35mm or 77mm in length. The parts for the entire system can be cut to length in two fixture setup runs(with a few exceptions).
- All cuts are 1-dimensional 90 degrees.
Scoop Extruder:
- Adjustable tension with no pulleys or pusher blocks.
- The "scoop" extruder uses the PTFE tube itself as the "idle pulley"
- It uses the Makerbot Mk5 nozzle and hot-end tube.
- Makergear style geared stepper.
- Raysyu drive gear.
- A Nophead style heater block.
Plotter Head: This single pivot floating head plotter arm works consistently over a very wide range of surfaces. The servo actuation provides fast on-off movements. The entire plotter arm and servo can be removed or switched with another pen without taking the pen out of position. The large 5/16" holding nut uses low force and acts as a knob that can be easily spun on/off by hand. The band clamp pen holder can hold just about any pen sized tool.
These are good resources for creating wiki pages. Very Messy Example and Columbus --Sebastien Bailard 07:23, 10 September 2010 (UTC)
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
1X2-File-Name | SOLID MODEL ASSEMBLY | These are CAD files for the Solid Model Assembly | .xml.zip, .stl.zip | --Mrkim 12:00, Today's Date 20xx (UTC) |
1X2-File-Name | CAD FILES FOR PARTS | These are CAD files for each part. | .xml.zip, .stl.zip | --Mrkim 12:00, Today's Date 20xx (UTC) |
1X2-File-Name | EVEN MORE FILES | These are are even more files. | .xml.zip, .stl.zip | --Mrkim 12:00, Today's Date 20xx (UTC)|- |
1X2-File-Name | SOLID MODEL ASSEMBLY | This is the final finished machine | N/A | --Mrkim 12:00, Tomorrow's Date, 20xx (UTC) |
Please edit this and click the links to put in your files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
