1X2 Shortcat
Revision as of 12:35, 4 June 2011 by Mrkim (talk | contribs) (Adjustable compliant bed:)
1X2_Shortcat
Release status: Working
Wooden RepStrap
none
Description:
The SHORTCAT is a 18″ tall, 12″ wide Pyramid framed 3D printer.
X-travel: 155mm
Y-Travel: 170-190mm
Z-travel: 210-220mm
This machine is made by: mrkimrobotics.com
Design:
The SHORTCAT applies TALLCAT style design in a more compact form factor.
By bending the supports into a pyramid shape, a symmetrical base is possible that uses no frame spacers. This significantly extends the x-axis travel and allows a 8″ wide table to exit the front and back of the machine on the y-axis. A thin-profile 360 bearing allows for clearance from the shorter pyramid.
Thin-profile x-assembly:
Drafting film (surface layer)
(table layer)
(compliance layer)
Parts:
1X2-x-carriage-v2.5.2.svg
1X2-y-carriage-v2.5.1.svg
1X2-y-carriage-motor-mount-v2.5.0.svg
1X2-y-carriage-pulley-mount-v2.5.svg
1X2-thin-profile-360-bearing-block-v2.5.svg
1X2-SHORTCAT-X-pulley-block-v2.5.svg
1X2-SHORTCAT-X-motor-block-v2.5.svg
1X2-scoop-extruder-2.0.svg
1X2-35mm-vertex-v2.0.svg
1X2-77mm-vertex-block-v2.0.svg
1X2-608-shim.svg
1X2-77mm-zigzag-arm.svg
Bill of Materials/Parts List
More Examples
