1X2 Silvercat
Revision as of 12:58, 21 September 2011 by Mrkim (talk | contribs) (Vinyl-Washer Vertex:)
1X2_Silvercat
Release status: Experimental
Shnny Metal RepStrap
none
Description:
Shoot for the Moon!
This project is for a zero tool requirement Repstrap.
Status: Unfinished
This frame vertex is made with vinyl tubing and two fender washers.
It requires no drilling or cutting beyond sectioning the tubing with scissors.
Materials: (1) 2" section of 3/8" OD x 1/4" ID vinyl tubing (2) fender washers (2) nuts
Assembly: Thread the tubing section onto the end of the threaded rod until it is tight. Form two triangles. Use the washers to clamp the ends of the cross bars to the inside of the vertex.
Z-motor mount:
This is a zero requirement z-motor mount.
The motor is lightly clamped between the fender washers. The inside nut keeps the clamping washer vertical.
The loop of tape secures the motor vertically.
