1X2 Tallcat
Release status: Experimental
Description | Elegant Wooden RepStrap
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Description:
Shoot for the Moon!
The 3ft tall 1X2 TALLCAT has a vertical build area of 640mm, yet it takes up no more desk space than the "Compact" Reprap 1X2. It has an increased X and Y build area as well.
This is a Pyramid Repstrap made with all 1-Dimensional 90 degree cuts.
The 1X2 and 1X2 TALLCAT are RepRap class 3D-printers that can be built with access to only a drill-press and hand-saw. The parts for the entire system can be made with one-dimensional tools, straight cuts and common materials.
First Test:
607mm tall single-walled tube(40mm diameter).
Z-Step: 0.30mm
Print Time: 5hr40min
This machine is made by: mrkimrobotics.com
Design:
The TALLCAT turns its biggest weakness, long flexible rods, into a strength by using the flex to triangulate the frame into a pyramidal structure. The rods bend out of the way of the z-bearing blocks as they ascend from the inside of the pyramid to the outside. This makes full end-to-end travel possible even with a highly acute frame.
Improvements:
- Eliminated frame spacers.
- Eliminated 45mm M3 bolts.
- Eliminated 25mm X-motor spacers.
- No more asymmetrical countersinks.
- Lower Table increases active Z-Travel.
- X-Travel increased to 160mm.
- Lighter X-Assembly.
- Simple pinch belt clamp has easy tension adjust and requires no through holes in the belt.
New:
- Vinyl shaft stops
- Dual Pivoting footed vertex allows adjustable bearing block alignment.
Parts:
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
1X2_Tallcat-File-Name | SOLID MODEL ASSEMBLY | These are CAD files for the Solid Model Assembly | .xml.zip, .stl.zip | --Mrkim 12:00, Today's Date 20xx (UTC) |
1X2_Tallcat-File-Name | CAD FILES FOR PARTS | These are CAD files for each part. | .xml.zip, .stl.zip | --Mrkim 12:00, Today's Date 20xx (UTC) |
1X2_Tallcat-File-Name | EVEN MORE FILES | These are are even more files. | .xml.zip, .stl.zip | --Mrkim 12:00, Today's Date 20xx (UTC)|- |
1X2_Tallcat-File-Name | SOLID MODEL ASSEMBLY | This is the final finished machine | N/A | --Mrkim 12:00, Tomorrow's Date, 20xx (UTC) |
