1X2 Tallcat
Revision as of 00:37, 17 April 2011 by Mrkim (talk | contribs) (Parts Y-Conveyor Version:)
1X2_Tallcat
Release status: Working
Elegant Wooden RepStrap
Description:
Shoot for the Moon!
The 3ft tall 1X2 TALLCAT has a vertical build area of 640mm, yet it takes up no more desk space than the "Compact" Reprap 1X2. It has an increased X and Y build area as well.
This is a Pyramid Repstrap made with all 1-Dimensional 90 degree cuts.
The 1X2 and 1X2 TALLCAT are RepRap class 3D-printers that can be built with access to only a drill-press and hand-saw. The parts for the entire system can be made with one-dimensional tools, straight cuts and common materials.
First Test:
607mm tall single-walled tube(40mm diameter).
Z-Step: 0.30mm
Print Time: 5hr40min
This machine is made by: mrkimrobotics.com
Design:
The TALLCAT turns its biggest weakness, long flexible rods, into a strength by using the flex to triangulate the frame into a pyramidal structure. The rods bend out of the way of the z-bearing blocks as they ascend from the inside of the pyramid to the outside. This makes full end-to-end travel possible even with a highly acute frame.
Improvements:
  • Eliminated frame spacers.
  • Eliminated 45mm M3 bolts.
  • Eliminated 25mm X-motor spacers.
  • No more asymmetrical countersinks.
  • Lower Table increases active Z-Travel.
  • X-Travel increased to 160mm.
  • Lighter X-Assembly.
  • Simple pinch belt clamp has easy tension adjust and requires no through holes in the belt.
New:
  • Vinyl shaft stops
  • Dual Pivoting footed vertex allows adjustable bearing block alignment.
Status:
  • The Y-Carriage version is fully working.
  • The stepper-driven conveyor-y-axis is physically sound but the control system is still being developed so it is experimental.
Y-Carriage Version:
This version uses traditional toothed timing belts and a one-piece Y-carriage design.
Video: <videoflash type="youtube">_WT4x1lXV2I|320|240</videoflash> <videoflash type="youtube">yagJJwZvnTQ|320|240</videoflash>
Parts Y-Carriage Version:
1X2-y-carriage-v2.4.svg
1X2-thin-profile-Y-motor-block-v2.1.svg
1X2-TALLCAT-footed-vertex-v2.2.svg
1X2-360-bearing-block-v2.3.svg
1X2-x-carriage-v2.3.svg
1X2-TALLCAT-X-motor-block-v2.3.svg
1X2-TALLCAT-X-pulley-block-v2.3.svg
1X2-TALLCAT-top-mount-belt-clamp.svg
1X2-scoop-extruder-2.0.svg
1X2-35mm-vertex-v2.0.svg
1X2-77mm-vertex-block-v2.0.svg
1X2-608-shim.svg
1X2-77mm-zigzag-arm.svg
Bill of Materials/Parts List
More Examples
