2xz+
Revision as of 15:33, 16 April 2016 by Iran (talk | contribs)
i3 2Xz+
[[image:I3-2xz.jpg|center|190px]]
The i3 2Xz+ is an
improved and enlarged Prusa i3.
GPLv2
The i3 Berlin is a improved and enlarged tested successor of the original Prusa Mendel i3.
Either you want to create a huge 40x20x30 machine from scratch or you want to upgrade your existing Prusa i3 (or its derivatives) to a machine with dual heated beds and more than doubled printing space, i3 2Xz+ is a well documented and tested machine suitable for you.
Assembly instructions
  1. Bill of materials
  2. Assembly manual
Improvements
All improvements where done after identifying problems of various prusa i3 based machines during 2 years of creating and selling reprap 3d printers. Many Open Hardware projects were used in this version, Which are carefully selected among a huge number of tested open source 3d printer parts and upgrades available online.
  • An enlarged rigid 10mm acrylic frame (any other suitable material can be used).
  • All electronics are supported, preferably 12v 30A power supply, Ramps 1.4, and the full graphic smart controller LCD display.
  • Wiring is managed perfectly, all the paths and routes are reconsidered, you won't need to invent any solution for managing wires.
  • Uses two separate [standard PCB mk2 heatedbeds] .
  • Dual Geared bowden extruder using MK7 extruder gears, Provide precision and power at the same time.
  • PSU switching is completely shielded and secured, There is a PC style On/off switch and power inlet added.
  • There are two well mounted ON/OFF Switches, one for the LED lights under the extruder heads, and the other one for manually enabling the second heated bed, in order to save energy on smaller prints.
  • Sufficient cooling system on ramps 1.4 board including two dedicated cooling fans one for regulators and one for stepper drivers.
How to get it?
I3-Berlin-Building-Kit-Web-Optimized.jpg 2-i3-Berlin-Perspective-Web-Optimized.jpg
What can you do with it.
Some prints from the i3 Berlin:
I3-Berlin-Print-Dog.jpg I3-Berlin-Print-Frog.jpg I3-Berlin-Print-RC rims.jpg I3-Berlin-Print-Robo Hand.jpg
Get in contact with us!
Please contact us through our website there is a contact form in the footer.
