3-D printable photovoltaic module spacer
Revision as of 18:10, 29 January 2019 by J.M.Pearce (talk | contribs) (See also)
Sunhusky.png By Michigan Tech's Open Sustainability Technology Lab.
Wanted: Students to make a distributed future with solar-powered open-source RepRap 3-D printing and recyclebot recycling.
Contact Dr. Joshua Pearce or Apply here
MOST on RepRap: Projects and Publications], Methods, Lit. reviews
Twitter updates @ProfPearce
RepRap 3-D printing has already been shown to be a versatile tool for fabricating novel photovoltaic racking designs, however, they can also be useful for installing conventional PV modules on conventional racking. In order to ensure appropriate spacing and well oriented array these open-source photovoltaic spacers can be printed. The design has been created to be parametric in OpenSCAD so this design can be used for any conventional array.
The concept and testing of the design was performed by SolarUP
The device is 100% 3-D printable and should be printed with a reasonable infill as this is a tool that will be used on a construction site. PLA is fine although other materials can be used.
Source Code
OpenSCAD
You can help Appropedia by contributing to the next step in this OSAT's.
All measurements in mm
s=6.35; //1/4 inch spacing
l=12.7; // 1/2 inch lip
d=25.5; // 1 inch down
x=127; //5 inch length
$fn=100;
union(){
cube([l+l+s,s,x], center=true); //lip
translate([0,-d/2-s/2,0])cube([s,d,x], center=true); //spacer
translate([0,d+5,0])cylinder(r=s, h=x, center=true);// handle
translate([0,d/1.5,d*2.25-.25])cube([d,1.5*d,d/2], center=true);// handle connector
translate([0,d/1.5,-d*2.25+.25])cube([d,1.5*d,d/2], center=true);// handle connector
See also
