ABS
Revision as of 03:30, 21 August 2012 by Dgm3333 (talk | contribs) (Extrusion width)
Introduction
Acrylonitrile Butadiene Styrene;(ABS) is a commonly used thermoplastic as it is lightweight and can both be injection molded and extruded. It has better mechanical properties than HDPE and less brittle than PLA but handles higher temperatures better for applications such as extruder's and X-carriages setups without a fan.
  • ABS is good because it is easier to buy and requires less force to extrude than PLA as it has a lower coefficient of friction. This makes its extrusion characteristics better for small parts, compared to PLA. The downside of ABS is that it has to be extruded at a higher temperature: anywhere from 215-250 Degreees C.
Fumes
ABS creates mild, tolerable fumes while being extruded. These fumes, while usually tolerable, may be dangerous for people (or pet birds) with chemical sensitivities or breathing difficulties. Rutkowski and Levin describe the possible combustion products of ABS in their literature review (Fire and Materials. Vol. 10, pp. 93-105 (1986) [1]).
Heater Settings
225-250 C, depending on your particular plastic.
Sample temperatures with a Makergear 0.5 mm hotend:
Ultimachine Red ABS: 215 C
Ultimachine Natural ABS: 230C
Extrusion width
There has been some evidence that pigment may affect extrusion width.
If you are switching plastics a lot, it is a good idea to measure the
extrusion before going through the toolpath process.
???True for ABS ??? --Sebastien Bailard 22:02, 27 April 2010 (UTC)
NB My ABS filament is quite soft, so a hobbed bolt cut with a dremel tool shreds it easily. A bolt cut with 3mm tap seems to work much better (at least with a Wades Extruder) --DGM3333 21 Aug 2012
Build Surface and distortions
ABS is bad because it tends to warp catastrophically off the build platform when printing large parts. This can be remedied by using a heated build platform (in which case it is just as nice as PLA and because it requires less force to extrude, is easier to print with!).
ABS will stick to acrylic at low temperatures and to PET or Kapton tape if the bed is hot.
On a cold bed ABS can be printed on masking tape by putting a thin layer of super-glue (cyanoacrylate) on the tape before printing (User:North90ty).
Availability
Printing Material Suppliers Also, check the forums... someone might be able to ship you some for cheap.
Further reading
