ActionCar
Revision as of 10:24, 26 June 2011 by Robsbots (talk | contribs)
May contain scaffolding.
This page may contain "scaffolding" - mediawiki text from the Example page that may not need to be there. It may help to delete the parts that you don't need. (more details)
3D Rendering of the ActionCar
ABS print of a 1/2 scaled down Action Car Chassis
A cool action car modelled by Patrick Prosic
File:ActionCar.zip
Notes
Zip file with stl files for car body, front and backwheels. The STL file has a slightly rounded bottom. This is bad if you want to print it. So I also included an AoI and STL file that has a flat base and cylidrical holes for the axes for the wheels - ActionCar_FlatBase.stl - if you want to print this then take this file. --Wizard23 05:57, 13 December 2008 (UTC)
