Adapto
Revision as of 23:37, 24 August 2013 by ROTORIT (talk | contribs) (Mounting the Y-axes)
Adapto
Adapto is a 3D printer that can be built with many different types of frames and frame materials.
GPL
ADAPTO
Screenshot of the .blend file
Info
The thought behind the Adapto 3D printer is that one can use the same printed parts on printers with different types of materials (in the frame).
The history behind this design is that i got hold of some alu extrusions that was intended to be used on a MendelMax. During the MM build i got so extremely annoyed with how over engineered it is so I decided to tear the MM apart in favor to make a design that only used 50% of the MM extrusions (that means i now have enough extrusions for 2 printers :D ).
I also designed the parts in a way that makes the builder able to use either Alu extrusions (20x20mm), wood, alu, acryl plates or plates made out of any material actually (if it is stiff enough).
I recommend not using anything thicker than 20mm thick plates/stripes (due to the y motor mount and y idler parts) and use max 34mm wide frame parts (due to the design of the feets), but thinner is ok if the material is stiff enough.
For an alu Adapto Walkaround Video, see http://www.youtube.com/watch?v=RWmtuGsg8Us
Some variants
Aluminum Adapto
A wooden adapto
As known this is a VERY "hackable" design and have a lot of options. It is impossible to cover all the things one can do to make the Adapto printer design work but if you are interested you can read about some more options and things that is possible on the Sample BOM for a Big T-Slot Adapto page. That BOM page lists parts, gives sample sources, and discusses possible alternatives.
ChristianS have made a awesome job making that page and it is highly recommended to pop by to read it.
Open your mind and let the creativity flow!
More info
This is also posted on:
The most up to date Files will always be on GitHub.
This is such an easy build it dont need much instructions.
  • Print the parts
  • choose your frame material
  • look at the pictures
  • BUILD IT! :D
Thanks to the entire RepRap- and Thingiverse- comunity for all the inspiration.
All the pictures can be viewed and downloaded from Thingiverse and GitHub
If you decide to build one, please feel free to add a pin on the Adapto map.
ENJOY!
Parts
Although this is a easy to build printer one need some parts for it.
  • RP parts that is the Printet plastic parts like extruder, smooth rod holders and parts that holds the frame together.
  • Frame that in this case is 20x20mm aluminum t-slot extrusions.
  • Smooth rods that in this case is 8mm thick.
  • Vitamins like screws, nuts, bearings, hobbed bolt, belts, pulleys springs and more.
  • Electronics that controls and drive the unit and also things like stepper motors, PSU, thermistors, heated bed, hot end, wires and more.
RP parts
This is the RP parts you need to build a 20x20mm alu extrusion framed Adapto with 8mm smooth rods, M5 Z-threaded rods and makes a 200x240mm build area with a Z travel up to about 270mm
So if you have a MendelMax frame laying around you can build 2 of this Adapto 3D printer :-)
Quantity Part Name Part Type Used Where Comment Looks like File Download
4
Y_Rod_Clamp_4_Off.stl
RP
Y rod clamps
Holds the Y smooth rods firmly to the frame. You need 4 of these for each Adapto printer you build.
For printing this part, recommended is 35% infill, 2 top/bottom/perimeter layers or more.
Y rod clamps
[1]GitHub,
[2]Direct
1
Y_Motor_Mount_1_Off.stl
RP
Y motor mount
Holds the Y motor to the frame. Fits a Nema 17 stepper motor just fine. You need 1 of this for each Adapto printer you build.
Y motor mount
[3]GitHub,
[4]Direct
1
Y_Idler_1_Off.stl
RP
Y idler
This is the Y axes belt idler that holds the Y belt idler bearing(s) firmly to the frame. You need to print 1 of this .stl file (that actually contains 2 plastic parts) for each Adapto printer you build.
Y idler
[5]GitHub,
[6]Direct
1
Y_Belt_Block_1_Off.stl
RP
Y belt block
This part is to be mounted under the bed. It holds both ends of the Y belt firmly to the bed making the stepper able to move the Y akses. The belt can for example be mounted to this with Zipties and make you able to get the belt nice and tight. You need one of this for each Adapto printer you build.
Y belt block
[7]GitHub,
[8]Direct
3
Y_Bearing_Holder_LM8UU_3_Off.stl
RP
Y bearing holders
Holds the Y axes bearings that slide on the Y smooth rods. Is to be mounted under the bed and holds a firm grasp on the y linear bearings of choice as long as the bearings have a outer diameter of about 15mm. You need at least 3 of these on each Adapto printer you build. Some people prefer to use 4.
Y bearing holders
[9]GitHub,
[10]Direct
2
Z_Motor_Holder_2_Off.stl
RP
Z motor holder
Holds the Z motors firmly to the frame. You need 2 of this for each Adapto you build.
Z motor holder
[11]GitHub,
[12]Direct
1
Z_Couplers_M5.stl
RP
Z couplers
Couples the Z threaded rods firmly to the Z motors. You need to print 1 of this .stl file (that actually contains 2 plastic parts) for each Adapto printer you build.
Z couplers
[13]GitHub,
[14]Direct
4
Foot_4_Off.stl
RP
Feet
Holds the lower frame firmly assembled and also work as the feet clearing the Z motors from the table keeping the nice look intact. You need 4 of these for each Adapto printer you build.
Feet
[15]GitHub,
[16]Direct
2-10
90_innerCorner.stl
RP
90 inner corner
Primary to support the frame on the opposite side of the extrusion from the Z_Smooth_Rod_Holder_Lower_2_Off.stl helps to keep the high frame at 90 degrees onto the lower frame. Recommended is to also use 4 more supporting the high frame in x direction. Some people also prefer to use even 4 more of these on the inside corner on the back side of the feet. Optional buy some metal corners to do the job if you like overkill and don't trust your mother.
90 inner corner
[17]GitHub,
[18]Direct
1
Extruder_Idler_1_Off.stl
RP
Extruder idler
Holds the extruder idler that squeeze the filament up against the hobbed bolt for consistent plastic feeding. Holds a 608 bearing with a short M8 threaded rot or preferably a sjort 8mm smooth rod. You need 1 of this for each Adapto Printer you build.
For printing this part, recommended is 60% infill, 2 top/bottom/perimeter layers or more.
Extruder idler
[19]GitHub,
[20]Direct
1
Large_Gear_T36_1_Off.stl
RP
Extruder large gear
Turns the hobbed bolt for filament feeding. It have 36 tooths and fits a M8 hobbed bolt nicely and have room for a M8 captive nut allowing it to lock on to the hobbed bolt using an additional nut. You need 1 of this for each Adapto printer you build.
Extruder large gear
[21]GitHub,
[22]Direct
1
Small_Gear_T13_1_Off.stl
RP
Extruder small gear
Sits on the extruder motor and turns the large gear. Locks to the motor axle with a M3 captive nut with M3 screw. You need 1 of this for each Adapto printer you build.
Extruder small gear
[23]GitHub,
[24]Direct
1
Extruder_X_Carriage_Combo_1_Off.stl
RP
Extruder carriage
This is both the X-carriage and extruder combined in one plastic part. It holds the weight of the nema17 close to the X-smooth rods to prevent shaking and holds the 3 linear bearings making the x akses slide smoothly. You need 1 of this for each Adapto printer you build.
Extruder carriage
[25]GitHub,
[26]Direct
2
RP
Z smooth rod holder lower
To hold the lower end of the Z smooth rod firmly to the frame. It fits a 8mm smooth rod nicely and ads another good looking part to the design. You need 2 of these for each Adapto printer you build.
[27]GitHub,
[28]Direct
2
Z_Smooth_Rod_Holder_Upper_2_Off.stl
RP
Z smooth rod holder upper
To hold the upper end of the Z smooth rod firmly to the frame. It fits a 8mm smooth rod nicely and ads another good looking part to the design. You need 2 of these for each Adapto printer you build.
[29]GitHub,
[30]Direct
1
X_End_Idler_1_Off.stl
RP
X end idler
Holds the X smooth rods, Z threaded rods firmly to the frame, the Z linear bearings in place and X idler in position to make the best possible print results. You need 1 of this for each Adapto Printer you build.
X end idler
[31]GitHub,
[32]Direct
1
X_End_Motor_1_Off.stl
RP
X end motor
Holds the X smooth rods, Z threaded rods firmly to the frame, the Z linear bearings in place and X motor in position to make the best possible print results. You need 1 of this for each Adapto printer you build.
X end motor
[33]GitHub,
[34]Direct
1
Endstop_Holders_X_3.stl
RP
Endstop holders
Holds the end stops firmly to the frame. Some changes may be expected in these soonish but will do for now. you need to print 1 of this STL (that actually contains 3 plastic parts) for each Adapto printer you build.
Endstop holders
[35]GitHub,
[36]Direct
Frame
Quantity Length Part Type Used Where Comment Looks like
2 300mm 20x20mm aluminum extrusion
2x300mm
This is the frame parts that determine the width of the frame.(X direction) Using 300mm extrusions here will result in about 250mm X-travel.
In other words, about 50mm loss of X-travel relative to these frame parts. (If you need for example 300mm X-travel you have to use 350mm extrusions here.)
You need 2 of these 300mm lengths for each Adapto printer you build.
Alu extrusions
2 340mm 20x20mm aluminum extrusion
2x340mm
This is the frame parts that determine the length of the frame.(Y direction) Using 340mm extrusions here will result in about 210mm Y-travel.
In other words, about 130mm loss of Y-travel relative to these frame parts. (If you need for example 300mm Y-travel you have to use 430mm extrusions here.)
You need 2 of these 340mm lengths for each Adapto printer you build.
Alu extrusions
3 420mm 20x20mm aluminum extrusion
3x420mm
This is the frame parts that determine the Height of the frame.(Z direction) Using 420mm extrusions here will result in about 270mm Z-travel.
In other words, about 150mm loss of Z-travel relative to these frame parts. (If you need for example 300mm Z-travel you have to use 450mm extrusions here.)
You need 3 of these 420mm lengths for each Adapto printer you build.
Alu extrusions
Smooth rods
Part Used Where Quantity Recommended minimum lengths. Comment Looks like
X-smooth rods
X smooth rods
2 400mm (Should this be 320? The others seem to be 20mm greater than the extrusion lengths. --evamvid) Can without problems be longer than recommended minimum lengths.
Smooth rods
Y-smooth rods
Smooth rods
2 380mm Can without problems be longer than recommended minimum lengths.
Y smooth rods
Z-smooth rods
Smooth rods
2 440mm Can without problems be longer than recommended minimum lengths.
Z smooth rods
Vitamins
work in progress..... Some more awesomeness coming soon here :-)
Electronics
How to build
Under construction ;-)
This guide is JUST A GUIDE and you don't have to follow this to the point. It is made to give you a good idea of how to do it and is not meant to be a ultimate blueprint of how to build the Adapto Printer. There might be a chance that you don't have the exact same parts as in this guide. The nuts might be slightly different, maybe you use thicker smooth rods and have the 10mm parts from the Adapto GitHub or maybe even use another frame material and color. There might be some upgrades that haven't been picked up and implemented in the guide just yet so please use it as a GUIDE, nothing else :-)
Anyway.. HERE WE GO! :D
Build step 1: Frame assembly.
Vitamins needed in this step
  • All Aluminum extrusions. 3x 420mm, 2x 340mm and 2x 300mm 7 lengths total
  • 89x T-slot nuts.
  • 47x M5x10mm screws.
  • 42x M5x12mm screws
  • 81x M5 washers (or 89 if you want to use washers on the Y-smooth rod holders).
  • 1x M8x40mm bolt (or some M8 threaded rod).(you need a bit longer bolt if you want to use lock nuts)
  • 4x M8 washers.
  • 2x M8 Nuts (+ 2, M8 lock nuts if you fancy that)
  • 2x 608 bearings.
RP-parts needed in this step
  • The 4 feet.
  • 10 corner brackets.
  • The 2 Y-idler parts.
  • The Y-motor mount.
  • The 2x Z-smooth rod holder upper parts.
  • The 2x Z-smooth rod holders lower parts.
  • The 4x Y-smooth rod holders.
  • The 2 Z-motor holders.
Mounted as shown in the pictures
1. Parts view.
2. Tools you may need.
3. Clean the parts if necessary.
4. Make sure the holes is big enough to fit your Vitamins. Some drilling might be needed.
5. Start by insering 2 T-slot nuts into one of the 340 extrusions and mount one of the corner brackets with 2x M5x10mm screws with washers like this(And continue to use washers on all the screws).
6. Insert 2 T-slot nuts into one of the 300mm extrusions and screw it onto the first 340mm extrusion with 2 more M5x10mm screws like this.
7. Insert 3 nuts into the inner slot of the 300mm Extrusion and add a corner bracket like this.
(Yes, all the corner brackets is to be mounted with M5x10mm screws)(or use M5x12mm + some additional washers to prevent them hitting the alu t-slot bottom) The 3rd nut is for the Y motor mount and can not be
added later on.
8. Insert 2x T-slot nuts into the other 340mm extrusion and mount it like this.
9. Insert 2 T-slot nuts into the inner slot of the 340mm extrusion and add another corner bracket like this.
10. Do the same on the other (side) 340mm extrusion.
11. Insert 4x T-slot nuts into the outer slot of the first 340mm extrusion. Then alide in 5x T-slot nuts in the top slot. Yes this is from now on, the top side of the lower frame
12. Same on the other side.
13. Slide 6x T-slot nuts in the inner slot of the last 300mm extrusion And slap it on like this.
14. Lay the entire lower frame onto a very flat surface (kitchen bench is usually flat enough), square it off and tighten the screws.
15. Start mounting the Top frame by sliding 2x T-slot nuts into the first 420mm extrusion and add a corner bracket like this.
16. Do the same on the socond 420mm extrusion.
17. Slide 4x T-slot nuts into the third(last) 420mm extrusion.
18. Lay all the 420mm extrusions on top pf the lower frame like this and mount the third extrusion to the first 2 420mm extrusions like this.
19. Use the lower frame as template to align and make sure the top frame have the same spacing and tighten the screws firmly.
20. Use 4x T-slot nuts to mount corner brackets on both sides of the top frame like this.
21. To mount the 2 top Z-smooth rod holders you need 3 T-slot nuts on each side.(Still M5x10mm with washers) (The fourth hole in these RP parts is to be used on wooden frames only). faten loosely. aligning comes later on.
22. Does yor result so far look like this too? IT SHOULD! :-)
23. Put the top frame aside for a while and pick a corner on the lower frame to start mounting the feet`s.(use M5x12 screws with washers on the feet`s) Each foot needs 5 nuts. 2 of them is already in there so you need to add 2 nuts in the top slot and 1 in the outer slot of the 300mm extrusion.
24. IMPORTANT. The next foot you mount must be on the opposite end of the 340mm extrusion that you mounted the first foot on.(To be able to add the right amount of t-slot nuts in the next few steps).
25. Slide 6x T-slot nuts into the top slot, 1 nut in the outer slot and 2 nuts in the bottom slot of the 300mm extrusion.
26. Mount the third foot.
27. Slide 6x T-slot nuts into the top slot and 2 nuts in the bottom slot and 1 nut in the outer slot of the 300mm extrusion on this side too.
28. Mount the fourth foot.
29. Assemble the Y-belt idler in this order. YES IT IS POSSIBLE TO USE ONLY 1x 608 BEARING IF YOUR BELT WITH ALOWS IT!!(cheapass) :p
30. Yes.. Mount the Y-belt idler on the 300mm extrusion that have 2x T-slot nuts in the inner slot. :-) Make sure the Y-belt idler bearing points inwards as seen in photos futher down in this guide. Use M5x12mm screws for this. YES WITH WASHERS!!
31. Add the Y-motor mount to the other side(on the 200mm extrusion oposite to the Y-belt idler) 1x M5x10mm screw on the single inner T-slot nut and 2x M5x12mm in the bottom slot.
32. Mount the 4x Y-smooth rod holders using 8x M5x12 screws with washers(if your washers can fit in the countersunk holes that is.). If not, use screws with big heads or.. (your imagination) These parts don`t need much force to hold onto the Y-rods. Just screw them on loosely, alignment comes later on.
33. Add the corner brackets, lower Z-rod holders and Z-motor holders like this. M5x10mm for the corener braskets and M5x12 for the rest. Screw them on loosely, aligning comes later on.
34. Mount the top frame to the lower frame like this. Pre mounting the T-slot nuts to the screws will make this a lot easier.
35. So far so good eh?
36. A real beauty is born.
37. LOOK AT THAT REAR END!! WOW!!
38. Top Model here we come!.
Assemble the extruder
  • 4x M3 nuts
  • 2x springs
  • 1x hobbed bolt
  • 3x 608 bearings
  • 2x M3x60mm
  • 5x M3 washers
  • 2x M8 Nuts
  • 2x M8 Washers
  • 1x M8x19mm bolt
  • 1x M3x25mm screw
  • 1x M3x6mm screw
  • 1x M3x10mm screw
  • 1x M3x8mm screw
  • 3x zipties
  • 3x linear bearings
  • Extruder_X_Carriage_Combo_1_Off
  • Extruder_Idler_1_Off
  • Small_Gear_T13_1_Off
  • Large_Gear_T36_1_Off
1. Parts view.
2. The E-stepper is mounted like this.
3. The 2x M3x6mm screws goes closest to the hobbed bolt.
4. And the M3x8mm with a washer on the fork. Don't tighten the screws just yet, so it is possible to move the stepper a bit .
5.Take the Hobbed bolt and add a washer and a 608 bearing to it.
6.Make sure the hobbing ligns up with the filament hole in the extruder body. use thicker or thinner washer/spacer to adjust.
7.Mount the other 608 bearing to the hobbed bolt.
8.and add the large gearwith a M8 nut.
9.Use the large gear to pressfit the bearing into the extruder body if it is tight,
10.take the large gear off again and add a washer under it.
11.and screw it back on.
12. Mount the small gear to the motor shaft
13.Push the stepper towards the large gear so the gears contact each other nicely and tighten the M3 screw on the fork to prevent it from shifting from this position any more.
14.Unmount the small gear.
15.and unmount the large gear.
16.so you can access the last 2 motor screws and tighten them.
17.Mount the large gear back on bit WITH the lock nut this time.
18.hold the large gear tight while you tighten the lock nut.
17.Mount the small gear back on and use the M3 nut and M3x10mm screw to lock it to the motor axle. Be sure the screw hits the flat on the axle. If the axle don't have a flat on it, MAKE ONE(use a file, Dremel or something)
18.Make sure the gears turn nicely. If they don`t somethig is to tight. but not make it so loose that it gets play between the gears because that will cause the gears hitting each other on retraction an wear out very fast.
19.Add a M3 nut into the Extruder Idelr RP part like this.
20.Then the M3x25mm screw like this.
21.Squeeze the bearing with the small M8 axle in like this and make sure it spins nicely.
22.It should now look like this.
23.make sure the slot in the idler fits your filament. file a bit if it is a tight fit.
24.Mount the Idler to the extruder body like this.
25.and screew ALL the 25mm in to make the idler fit and tilt nicely.
26.Add a M3 nut in each of these 2 holes so they lign up with the holes on the side where the spring screws goes next.
27.I dont know why i took this picture but... looks good eh? :-)
28.Mount the springs with washers on both sides on the screws ans screw them into the nuts you added in step 26.
29.humm.. yeah.. it should now look like this :D
30.Exactry like this... :/
31.Use the zipties to mount the linear bearings.
32.It is a good idea to have a rod trough these when you tighten the zipties on these 2 so they lign up perfectly.
Mounting the X/Z axes
  • 2x 8mm smooth rods x 440mm
4 center* 2x 8mm smooth rods x 405mm
  • 2x M5 threaded ros x 400mm
  • 6x M5 nuts
  • 8x M3 washers
  • 8x M3 nuts
  • 10x M3x12mm screws
  • 4x M3x16mm screws
  • 1X M3x25mm screw (M3x 16 will probably do the job too)
  • 4x Linear bearings that fits the mm smooth rods
  • 8x zipties
  • X_End_Idler_1_Off
  • X_End_Motor_1_Off
  • 2x Z_Couplers_M5
+ 2x Nema 17 for the Z lift
Also you need the extruder you assembled earlier.
1.Start by mounting the Z-lifting nema 17 steppers with the 8x M3x12mm screws. mount them loosely as you probably need to adjust them later on.
2.Put a M3 nut in each z couplers with a M3x12mm screw in them like this.
3.And mount them on the Z motors like this.
4.Use 2x M3 nuts to mount the Z zero height addjuster M3x25mm screw like this and use the 8 zipties to mount your linear bearings like this.
5.Insert the 4 lock nuts for the X-smooth rods into the x-ends like this.
6.and hold them nuts in place with the 4X M3x16mm screws like this.
7.Mount 2Xm5 nuts on each of the M5 rod ends and screw them towards each other to lock them in place like this.
8.Insert the M5 nuts into the x ends like this.
9.Screw the M5 threaded rods into the M5 nuts trough the x ends like this.
10.Screw them all the way inn so they look a bit like this.
11.mount the x end to the z-couplers like this(here shown the X idler)
12.Poke the 8mmx440mm smooth rods trough the Z zmooth tod holder upper RP parts like this.
13.slide them into the x end idler linear bearings like this and further into the lower Z smooth rod holders.
14.Now do the same with the X-end motor part.
15.the z-smooth rods should go all the way trough the RP parts until it hits the alu extrusion.
16.Poke the upper X-smooth rodthis far into the X-end idler.
17.and add the extruder like this.
18. a closer look :-) and poke the smooth rod all the way until it hits the bottom of the hole in the x-end motor RP prart.
19.Now poke the other X smooth rod trough the X-end idler, trough the extruder bearings and further into the X-end motor RP part.
20.If the x ends is not 100% on same height make them so and then lock the x rods tight with the lock nuts and screws.
21.Now it should look like this..
22.And this
23.Adjust the z motors so the z threaded rosd is paralell witht the z smooth rods both in x and y direction. Just eyeball it as it is good enough. Then screw the z motors tight to the motor holders and then motor holders to the frame so they don't shift anymore
24. Imagine a picture of your own proud and happy face here :-)
Mounting the Y-axes
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
Documentation in progress
