Alubot
Revision as of 14:39, 11 September 2013 by KalleP (talk | contribs)
Alubot
Alubot is one of the easiest to build Reprap 3D printer, and uses Aluminum t-slot as frame.
GPL
none
none
ALUBOT
Screenshot of solidworks assembly of the Alubot
Info
Alubot aims at beeing one of the easiest 3D printers to build at a low cost, and uses the concept of Reprap to do so. Alubot consist of 7 equally long t-slot aluminium extrusions, 10 90degrees brackets, 4 smoothrods, 2 threaded rods, 5 motors and more. Alubot is easy to scale, by adjusting the length of the aluminium extrusions, smooth rods and the threaded rods. but i would still advice to build the printer for a printarea of 20x20cm for a first time builder.
Parts
Updates shortly
RP Parts
The following is a list of what needs to be printed:
Quantity STL file Comments Picture
X-AXIS
1 jonaskuehling_xcarriage_lm8uu.stl you can choose which ever X-carriage as you like, but i'll include this since it's a robust and good carriage Jonaskuehling xcarriage lm8uu.png
Y-AXIS
Z-AXIS
OTHER
Vitamins
Updates shortly
Electronics
Updates shortly
