Alubot
Revision as of 10:36, 11 May 2013 by Robinarvidsson (talk | contribs)
Alubot
Release status: concept
Description | Alubot is one of the easiest to build Reprap 3D printer, and uses Aluminum t-slot as frame.
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | none
CAD Models | none
External Link | none
ALUBOT
Info
Alubot aims at beeing one of the easiest 3D printers to build at a low cost, and uses the concept of Reprap to do so. Alubot consist of 7 equally long t-slot aluminium extrusions, 10 90degrees brackets, 4 smoothrods, 2 threaded rods, 5 motors and more. Alubot is easy to scale, by adjusting the length of the aluminium extrusions, smooth rods and the threaded rods. but i would still advice to build the printer for a printarea of 20x20cm for a first time builder.
Parts
Updates shortly
RP Parts
The following is a list of what needs to be printed:
Quantity | STL file | Comments | Picture |
X-AXIS | |||
1 | X-Endstop_Motor.stl | ||
1 | X-Endstop_bearing.stl | ||
Y-AXIS | |||
1 | Y-BearingHolder.stl | ||
1 | Y-Motor_holder.stl | ||
4 | Y-LM8UU_Holder.stl | ||
4 | Y-8mm-Smootrod_Holder.stl | ||
Z-AXIS | |||
2 | Z-motor_holder.stl | ||
OTHER | |||
10 | Bracket_90degree | These can also be bought in metal |
Vitamins
Updates shortly
Electronics
Updates shortly
