Alubot
Alubot
Release status: concept
Alubot is one of the easiest to build Reprap 3D printer, and uses Aluminum t-slot as frame.
GPL
none
none
none
ALUBOT
Screenshot of solidworks assembly of the Alubot
Info
Alubot aims at beeing one of the easiest 3D printers to build at a low cost, and uses the concept of Reprap to do so. Alubot consist of 7 equally long t-slot aluminium extrusions, 10 90degrees brackets, 4 smoothrods, 2 threaded rods, 5 motors and more. Alubot is easy to scale, by adjusting the length of the aluminium extrusions, smooth rods and the threaded rods. but i would still advice to build the printer for a printarea of 20x20cm for a first time builder.
Parts
Updates shortly
RP Parts
The following is a list of what needs to be printed:
Quantity STL file Comments Picture
X-AXIS
1 X-Endstop_Motor.stl [[File:x-endstop_motor.png|300px|thumb|center|]
1 X-Endstop_bearing.stl
Y-AXIS
1 Y-BearingHolder.stl
1 Y-Motor_holder.stl
4 Y-LM8UU_Holder.stl
4 Y-8mm-Smootrod_Holder.stl
Z-AXIS
2 Z-motor_holder.stl
OTHER
10 Bracket_90degree  These can also be bought in metal
Vitamins
Updates shortly
Electronics
Updates shortly
