Aluhotend
Aluhotend
Release status: in production
Aluminium and Stainless steel hotend for general purpose printing with ABS Nylon and PLA , designed as a drop in replacement for the jhead
NC
Introduction
This is the Aluhotend in it's most current format currently it is a 4 piece design:
Heatsink - all of these are manufactured with a 2.5mm hole in the entry is drilled out before shipping to cater for 3mm use, the mounting point is dimensionally identical to the [jhead] and should mount in anything the jhead does.
Thermal Barrier - these have taken a few forms before this one most of them have been turned and reduced in diameter from the outside leaving no room for a ptfe liner, the latest version the thermal barrier is a 35mm length of stainless steel threaded rod with a hole bored through it at 4mm , then either a 2mmID 4mmOD or a 3.15mmID4mmOD ptfetube is inserted.
the advantage with this configuration is that not only is the liner held captive by the heatsink the large diameter on the thermal barrier provides a great deal of strength and protect against crashes into the bed which would cause damage to previous versions.
Heater Block - the design is based more on machining capability in the early stages than anything, it has 4 holes 2 of them are threaded the M4 threaded hole takes an M4 grub screw for retaining a heater cartridge or a resistor in the 6.5mm hole, the 6.5mm hole done at 6.5mm due the problems with heater cartridge diameters, which while they are sold as 6mm in diameter that isn't actually the case, some of them are oval in shape and will get jammed in a 6mm hole, making replacement impossible with damaging the heater block the holes for the thermistor are 2mm and 2.5mm which allows the use of a through hole type of thermistor the reasons behind this were mainly safety, the thermistor cannot physically fall out leaving the hotend to overheat.
Nozzle - the nozzle is a fairly standard M6 threaded nozzle, you can use just about any of the commonly available nozzles for the up! or makerbot and various other hotends which use an M6 threaded nozzle.
Assembly
1 - screw thermal barrier into heatsink (todo: insert pictures here)
2 - screw nozzle into heater block all the way (todo: insert pictures here)
3 - insert ptfe liner into thermal barrier cut off with about 6mm remaining on the end (todo: insert pictures here)
4 - screw thermal barrier into heaterblock until it hits the nozzle (todo: insert pictures here)
5 - back off nozzle by 1/2 turn (todo: insert pictures here)
6 - tighten thermal barrier by 1/4turn (todo: insert pictures here)
7 - tighten nozzle against thermal barrier (todo: insert pictures here)
Usage
can be used normally just like most other hotends, one suggestion for easy feeding especially with 3mm filament is to cut the filament at an angle so that the pointy end wants the curl into the middle of the tubing, this will allow the filament to slide all the way down instead of a 90 degree curly end digging into the ptfe liner, this is somthing that should be done on any ptfe lined hotend to maintain the integrity of the ptfe liner and make it last as long as possible
Suppliers
Supplier Name Location link feedback
3D industries Australia Australia link -
Summary: V5 Aluhotend.
Drawings
nozzle:
Internal hole depths: 2mm hole depth: this value determines the length of the orifice, ideally the orifice length should be about 0.5mm calculate this based on your drill type,
the 3.5mm hole is 7mm deep any less and it no longer becomes a compatible replacement for the up! nozzles,
  • this value is likely to change in the future and we may have to make up different nozzles, for different hotends eg highspeed and retractionless,
Thermal Barrier:
Heater Block:
Heatsink:
