Arduino Mega Pololu Shield
Revision as of 08:20, 29 December 2010 by LImbus (talk | contribs) (Bill of Materials: added reichelt order numbers)
RAMPS
Release status: Working
A RepRap etch resist printable circuit board that fits on the Arduino MEGA and holds interchangeable stepper driver carriers and the rest of RepRap's electronics. Arduino MEGA based modular RepRap electronics.
Summary
RepRap Arduino Mega Pololu Shield, or RAMPS for short. It is designed to fit the entire electronics needed for a RepRap in one small package for low cost. It is a single layer designed board that is printable on your RepRap with the etch resist pen method, or home fabbed with toner transfer. At the same time it is based on the powerful Arduino MEGA platform and has plenty room for expansion. The modular design includes plug in stepper drivers and extruder control electronics on an Arduino MEGA shield for easy service, part replacement, upgrade-ability and expansion. Additionally as long as the main RAMPS board is kept to the top of the stack a number of Arduino expansion boards can be added to the system.
Features
  • It has provisions for the cartesian robot and extruder.
  • Expandable to control other accessories.
  • 3 mosfets for heater / fan outputs and 2 thermistor circuits.
  • Fits 4 Pololu A4983 stepper drivers
  • Pololu boards are on pin header sockets so they can be replaced easily or removed for use in future designs.
  • The pin headers for the stepper motor outputs are placed on top of the Pololu boards saving routing them on the main shield.
  • I2C and SPI pins left available for future expansion.
  • All the Mosfets are hooked into PWM pins for versatility.
  • Servo style connectors are used to connect to the endstops, motors, and leds. These connectors are gold plated, rated for 3A, very compact, and globally available.
<videoflash type="youtube">0k_KArg_sgA</videoflash>
Support
Development
If you're reading this, you're probably a reprap-developer. We'd be honored if you join the reprap-dev mailing list and help make RAMPS better.  :D
Assembly Instructions
The printed bottom of the board.
Component Soldering
Shield Assembly
Use your preferred circuit board manufacturing method. :) If you are doing point to point wiring make sure to read that section first
  1. Top wires. (This step is not required if using a two sided PCB) Make sure they are clear of other components to be soldered later
  2. Resistors as shown to the right.
  3. Small 100nF capacitor, C4
  4. LED - short pin towards the wider opening in the symbol, down in this case.
  5. Cut the 2 row pin headers into 2x3 (6)blocks, 7 of them needed. Solder these for microstep selection jumpers, and endstop jacks. It is easiest to place all these and hold them in place with a card to flip board for soldering.
  6. Cut the 1x10 pin header to 4 pins long and solder it in the T1 T0 holes for thermistor jack. Solder one of the end pins first, straighten the pins to be perpendicular to the board and solder the rest of the pins.
  7. Four 1x16 socket headers into place for the stepper driver sockets. (If you have 1x20 socket headers, cut them down to 1x16)
  8. Power connector, X1, the 2 pin fixed/pluggable terminal block.
  9. Screw terminal block, (6 pin)
  10. Reset switch, S1, push button switch
  11. Pass-through headers that will connect the shield to the Arduino board (around the perimeter of the board). Can be later for short pin headers. This includes the one 2 x 18 Pin Stackable Female Header, the five 1 x 8 Pin Stackable Female Header and the one 1 x 6 Pin Stackable Female Header.
    • More recent kits include 2x18, 1x22, and 1x24 pin headers for connection to the Arduino MEGA. Cut the 1x22 into 1- 1x6 + 2- 1x8 lengths. Cut the 1x24 into 3- 1x8 lengths. If you insert these into the Arduino MEGA to hold them straight while soldering, take care not to heat for too long risking melting the Arduino's connector.
  12. Solder the large capacitors, C4, the 100nF capacitor, C5,C8 10uF capacitor as shown lower right.
    • They must be inserted in the correct orientation. + to the top for C4 and C5 or left for C8.
  13. Mosfets, Q1,Q2,Q3, the three N-channel Mosfet, STP55NF06L
    • They must be oriented in correctly (as per photographs)
  1. The big yellow MF-R500 fuse, F1.
  2. D1, the 1N4004 diode.
    • The diode can be omitted, it may be needed in the future for printing from SD or USB. This will power the Arduino from the shields 12V input. Diodes must be oriented correctly. If you are using higher than 12V to power the shield you should omit the diode to prevent damage to the Arduino and stepper drivers.Warning: The high side of the stepper boards are designed to accept up to 35V, but if you do this the heater and other high side outputs will be at that voltage also. You may need to adjust the heater resistance, etc.
  3. Thoroughly check for shorts (This is crucially crucial for DIY etched boards.)
    • Check for continuity between each and every pin to the pins next to them and GND, 12V, 5V (VCC).
    • Set your meter to beep for continuity, hold a probe on GND and check all soldered pins. If it beeps check if it is supposed to be GND and contine. Repeat for 12V and 5V.
Stepper Driver Boards
  1. Solder the pin headers on to the stepper driver boards.
    Close up of Pololu Driver Board
    • For this design the power and control pins go down towards your new shield and the motor pins(1a,2b,2a,2b) on top of the board (component side) so the motors can be plugged directly in.
    • See image on right.
    • Glue the heatsink to the top of the A4983 chip using the provided pad of double-sided adhesive.
Make the cables up for the opto endstops
    • Cut the 26awg 3 conductor cable into 3 length.
      Close up of endstop connector on endstop.
    • Note: you may want until you've built your machine to cut the cables to the perfect length.
      Close up of endstop connection on RAMPS
    • WARNING In order to keep the PCB at a printable resolution two wires have been flipped from the traditional opto endstop boards. The signal pin has been moved to the outside of the connector.
    • Hooking these up incorrectly can damage the components.
    • vcc=red, sig=white, gnd=black
    • Endstop End: Vcc-Sig-Gnd ; Shield End Vcc-Gnd-Sig
    • solder a female connector to the ends of each wire.
    • use the 2.54mm 1x3 housing.
    • Connect at least the minimum endstops.
Put the connectors on the motor wires
    • EDIT???????????????????????????????????????????????
    • Shown is the type used for servos in RC projects. See Stepper Motors for info on motors.
Thermistor Wires
Use a 4 pin 0.1" connector to terminate the thermistor wires.
    • Use the two receptacles on one end, leaving the other two open for extra thermistors.
    • Connect the cable so the 2 wires go to T0
  1. Connect the 2 heater wires to E0H and the + connection above it.
    • If changing to an unverified firmware it is best to verify heater circuit function with a meter before connecting heater to prevent damage to the extruder.
Connecting Power
power connection, +/-
The power connector plug may not be obviously labeled, looking at the power connection the positive is on the left and the negative is on the right of the plug.
Power Supply
RAMPS is quite happy with the 12 V line from PCPowerSupply. Or you can hack up a 12V laptop power supply, or other 12 V "wallwart" power supply. Be sure that the power can output 5A or greater.
Maximum Input Voltage
Power Supply without diode
The 1N4004 diode connects the RAMPS input voltage to the MEGA. If your board does not have this diode soldered in, you can safely input as much as 32 V. (The pololus can do up to 35V)
Power Supply with diode
If your board has a 1N4004 diode soldered in, do not apply more than 12 V to it. Original flavor Arduino Mega are rated to 12 V input. While Arduino Mega 2560 can take 20 V, it is not recommended.
Point to point wiring when using a proto shield
This is the front of the shield.
The traces that need cut on the Tinker-It shield.
It is possible to make this circuit with a proto shield by running wires directly between the pins. Make sure to check the prototype shield you use for pin holes that have traces tying them together. You most likely will have to cut some traces to keep from shorting circuits together. The board used here is the Arduino Mega shield one manufactured by Arduino. I only had to cut traces in about 4 places and it only took a couple seconds each with the little grinding bit on a dremel tool. Pictured below are the traces that need cut on the Tinker-It shield, both traces need cut in the small red circle, the top trace cut twice in the big circle to isolate the pins there.
If wiring a shield make sure to leave the area above the usb jack and ISCP header clear of components or the board is spaced / electrically insulated sufficiently to avoid shorts to the Arduino Mega board components.
Firmware and Pin Assignments
You will need the Arduino software at http://www.arduino.cc/en/Main/Software to upload the firmware to Arduino Mega.
Working preconfigured firmwares are available at:
https://github.com/johnnyr/Tonokip-Firmware works excellently with RepSnapper and Skeinforge
https://github.com/ramps/FiveD_for_RAMPS_GCode_Interpreter for use with Host Software and supposedly ReplicatorG
Here are the pin definitions for this board.
RAMPS v1.1c
The following values need to be entered to "Arduino Mega pin assignment" in the "pins.h" file of the firmware if not already configured.
// RAMPS v1.1c
#define DEBUG_PIN        13
#define X_STEP_PIN (byte)26
#define X_DIR_PIN (byte)28
#define X_MIN_PIN (byte)3
#define X_MAX_PIN (byte)2
#define X_ENABLE_PIN (byte)24
#define Y_STEP_PIN (byte)38
#define Y_DIR_PIN (byte)40
#define Y_MIN_PIN (byte)16
#define Y_MAX_PIN (byte)17
#define Y_ENABLE_PIN (byte)36
#define Z_STEP_PIN (byte)44
#define Z_DIR_PIN (byte)46
#define Z_MIN_PIN (byte)18
#define Z_MAX_PIN (byte)19
#define Z_ENABLE_PIN (byte)42
// Heated bed
#define BED_HEATER_PIN (byte)8
#define BED_TEMPERATURE_PIN (byte) 1
//extruder pins
#define EXTRUDER_0_STEP_PIN (byte)32
#define EXTRUDER_0_DIR_PIN (byte)34
#define EXTRUDER_0_ENABLE_PIN (byte)30
#define EXTRUDER_0_HEATER_PIN (byte)10
#define EXTRUDER_0_TEMPERATURE_PIN (byte)2
#define EXTRUDER_1_STEP_PIN (byte)23
#define EXTRUDER_1_DIR_PIN (byte)25
#define EXTRUDER_1_ENABLE_PIN (byte)27
#define EXTRUDER_1_HEATER_PIN (byte)9
#define EXTRUDER_1_TEMPERATURE_PIN (byte)8
RAMPS v1.0
Original PCB that was available from Ultimachine in Sept 2010.
This board can be used with FiveD without modifications with the above pin definitions. The extruder heater ouptuts will be on the screw terminals marked D10. You can cut the traces on top of the board and wire pins 8 and 9 to the other 2 mosfets if needed for heated bed, etc. Pins 11 and 12 can not currently be used with the FiveD firmware due to a conflict with the interupt timer . The following pin definitions can be used with Tonokip_Firmware(Note baud rate defaults to 115200 in this firmware) controlled by RepSnapper Manual:Introduction software.
// RAMPS v1.0
#define X_STEP_PIN         26
#define X_DIR_PIN          28
#define X_ENABLE_PIN       24
#define X_MIN_PIN           3
#define X_MAX_PIN           2
#define Y_STEP_PIN         38
#define Y_DIR_PIN          40
#define Y_ENABLE_PIN       36
#define Y_MIN_PIN          16
#define Y_MAX_PIN          17
#define Z_STEP_PIN         44
#define Z_DIR_PIN          46
#define Z_ENABLE_PIN       42
#define Z_MIN_PIN          18
#define Z_MAX_PIN          19
#define E_STEP_PIN         32
#define E_DIR_PIN          34
#define E_ENABLE_PIN       30
#define LED_PIN            13
#define FAN_PIN            -1
#define PS_ON_PIN          -1
#define KILL_PIN           -1
#define HEATER_0_PIN        12
#define TEMP_0_PIN          2   // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
Schematic
This is the schematic of the shield.
Warnings
The endstop pins are Signal - VCC - GND, instead of the VCC - Sig - GND like the rest of RepRaps boards. Make sure to wire them correctly. This is done to allow squeezing fatter traces on the printable board.
Initial Initialisation
If you think you may have mistakes you can install only one stepper driver during initial testing and risk only one stepper driver.
The trimpot on the stepper drivers controls the current limit. Turn it all the way down (counter clock wise) and back up 25%. Be careful to not force the trimpot, it is delicate. You will need to fine tune the current limit later.
Install firmware as shown above.
((((((Add more here))))))))))
Ingredients
Source
FILE ID# TYPE DESCRIPTION DOWNLOAD
File:ArduinoMegaPololuShield.zip Eagle Files These are the files you need to make the boards media:ArduinoMegaPololuShield.zip
File:RepRapjr.lbr Eagle Libraries The components used in this board are here. see Eagle_Library media:RepRapjr.lbr
This board is mostly based on Adrian's Pololu_Electronics and work by Tonok. copper etch resists methods suggested by Vik circuit design based mostly on Adrian's Pololu_Electronics Used Joaz's pin definitions for initial layout
Bill of Materials
ID Description Quantity Part Number Reichelt Order Number
U1 Arduino Mega 1
U2,U3,U4,U5 Pololu A4983 carrier 4
C4 100nF capacitor 1 KERKO 100N (to be verified)
C5,C8 10uF capacitor 2 RAD 10/35 (verified)
C6 100uF capacitor 1 RAD 100/25 (verified)
R1,R7 4.7K resistor 2 METALL 4.70K
R2,R3,R4,R5,R6,R8,R9 100K resistor 7 1/4W 100K
Q1,Q2,Q3 N-channel Mosfet 3 STP55NF06L ZXM 64N035 L3
D1 Diode 1 1N4004 1N 4004
F1 PTC resettable fuse (30V, Hold5A, Trip10A) 1 MF-R500 PFRA 500
J2 5.08 Eurostyle screw terminal 1 282837-6 (waiting for next delivery)
LED1 5mm Green LED 1
S1 Push button switch 1 FSMRACD TASTER 3305B
X1 Power jack 1 MSTBA1 (5.04mm spacing 2 connector) AKL 249-02 AND (AKL 230-02 OR AKL 220-02)
2 x 12 pin header 2
2 x 9 pin header 1
10 pin header 1
2 x 18 Pin Stackable Female Header 1 MALE: SL 2X25G 2,54 (shortened with a saw or pliers)
8 Pin Stackable Female Header 5
6 Pin Stackable Female Header 1
16 Pin Female Header 4 BL 1X20G8 2,54 (shortened with a saw or pliers)
Circuit Board 1 v1.1
I ( lImbus) am currently (2010/12/29) about to configure a "reichelt Warenkorb" for zeh Germanz with us. I expect the BOM of the standard electronic parts to be about 10 Euro in total.
Wish list
This shield would like to replicate with the following external boards
  1. Additional Stepper Driver
  2. DC Driver
  3. Thermistor
  4. Thermocouple
  5. SD Card
  6. Control Panel w/LCD
  7. Ethernet
  8. Host USB
Electronics Enclosure
OK, this is an enclosure for the RAMPS. It has a mount built in for a 40mm fan and LED.
Shown printed in PLA. There is talk that it is currently unprintable in ABS due to warping.
It uses 2.8mm holes to for the 3x16mm cap screws that mount it and the Arduino stack inside. These holes print a little undersized with my configurations and hold a 3mm screw pretty good.
IMAGE FILE ID# TYPE DESCRIPTION DOWNLOAD
RAMPSoutside.jpg File:RAMPS1-1case.zip STL All the stl files for the v1.1 enclosure in a zip media:RAMPS1-1case.zip
Case transparent.jpg File:RAMPS ADfiles.zip Alibre Design Files These are the original design files. media:RAMPS ADfiles.zip
Top.jpg RAMPS-Case-Top3 STL The lid for the enclosure. Has mount for 40mm fan. Chose the one that fits your vs of the board with or without UltiMachine logo. media:RAMPS-Case-Top3v1-1.stl
media:RAMPS-Case-Top3v1-1noUlogo.stl media:RAMPS-Case-Top3v1-0.stl
media:RAMPS-Case-Top3v1-0noUlogo.stl
Base.jpg RAMPS-Case-Base3 STL The bottom half of the enclosure. Chose the one matching your vs. media:RAMPS-Case-Base3v1-1.stl
media:RAMPS-Case-Base3v1-0.stl
Window.jpg File:RampsWindow.stl STL Covers teardrop holes and serves as reset button lever media:RampsWindow.stl
Resetbutton.jpg File:RampsResetButton.stl STL Attached through window with 3mm filament. media:RampsResetButton.stl
MountSpacer.jpg File:RampsMountSpacer.stl STL Spacer to raise enclosure up above the bottom nut outside the frame vertex. media:RampsMountSpacer.stl
Showcase
Change Log
  • v1.1 September 30, 2010
  1. Replaced power barrel jack with plug-able screw terminal
  2. Added jumpers to select micro-stepping on stepper driver boards
  3. Added debug LED
  4. Changed mosfet pins to be compatible with FiveD firmware
  5. Reduced number of 100uF capacitors to 1
  6. Added 100nF capacitor to 12V input
  7. Put auxiliary 12VIN and GNDIN pads in a straight line
  8. Silk Screen and bottom layer cleaned up
  • v1.0 Original RAMPS PCB design
  • v0.1? Point to point wired Arduino MEGA Prototype shield
Trouble Shooting
  • Check List
  1. RAMPS shield firmly seated on Arduino MEGA
  2. No stray wires/metal to cause short
  3. All connections firmly seated, screws tight
  4. Power connection oriented correctly
  5. Thermistor connected to T0
  6. Firmware uploaded
  7. Stepper driver potentiometers to a sane setting
  8. Heater wires properly connected
Heated Bed
Warning: Do not attempt this if you are afraid your mosfet will release magic smoke. This has not been tested on V1.0, and might not work as well due to thinker mosfet traces It is possible to run your heated bed off of the RAMPS shield without a relay. Some users may be inclined to use a mosfet as it will release magic smoke and cut power, rather than a relay's inclination to fail in the closed state. How to: You need to jump the two pads where the resettable (yellow) fuse normally goes. The through holes are small, but the pads are big, so it is better to use a larger gauge wire and solder on the pads. It is not as mechanically strong, but will let you use a bigger wire. On the Version 1.1 shield, it might be best to use D8, as it has thicker traces.
