Artifex
Revision as of 00:07, 11 January 2014 by 3DMakerWorld (talk | contribs)
3DMakerWorld Artifex
Release status: Working
Open source desktop 3D printer
CC BY-SA 3.0
Introduction
The 3DMakerWorld Artifex is an open source desktop 3D printer. It makes three-dimensional objects out of PLA and ABS filaments layer by layer. The printer's frame is based on the frame of MendelMax-2.0, and the design was heavily modified for printability, strength, wire management, vibration reduction, filament feeding, and compatibility with other features in the extruder and heated build platform.
3DMakerWorld Artifex Front.jpg 3DMakerWorld Artifex Left.jpg 3DMakerWorld Artifex Right.jpg 3DMakerWorld Artifex Back.jpg
Specifications
Printing
  • Print technology: Fused Filament Fabrication
  • Print space (W x D x H): 230 x 310 x 190mm (9 x 12.2 x 7.5in)
  • Print volume: 13,547cm^3 (827 in^3)
  • Height extendable to 220mm (8.7in) in the middle of X-axis for additional 198 × 310 × 30 mm (1,841cm^3, or 112in^3) space
  • Layer resolution: 0.05mm (0.002in)
  • Nozzle diameter: 0.35mm (0.014in)
  • Print materials: 1.75mm PLA and ABS
  • Speed:
    • Top print speed: Infill or inner perimeter: 150mm/sec; Outer perimeter: 100mm/sec
    • Top non-print speed: 300mm/sec
  • Acceleration
    • Top print acceleration: Infill: 3000mm/sec; Perimeter: 1500mm/sec
    • Top non-print acceleration: 3000mm/sec
Electrical
  • Power requirements: 110/220 VAC
  • Electronics: RAMBo
  • Hot-end: MakerGear hot-end with 0.35mm nozzle
  • Heated bed: 24V 200W heated bed up to 120C
  • Cool fans: Three 24V cooling fans for filament drive, print surface, and electronics
Mechanical
  • Overall dimension (W x D x H): 484 x 482 x 480mm (19 x 19 x 19in)
  • Weight: 11Kg (24lb)
  • Frame: Aluminum extrusions
  • Motion:
    • X and Y axis: linear rails and GT2 belts
    • Z axis: precision linear shafting and ACME leadscrews
  • Printed parts: Black ABS
Instructions
Buying Guide
The 3DMakerWorld Artifex 3D Printers are available at http://www.3dmakerworld.com/store/3dprinters in different packages:
  • Hardware kit: All the hardware parts in the packing list of Artifex 3D Printer.
  • Essential kit: Print out your own parts. Everything else is included.
  • Complete kit: Everything included: hardware, electronics, printed parts and tools.
  • Fully assembled: Comes with a fully assembled Artifex 3D Printer. Ready to set up and print.
More Information
