AssemblingDarwinMachinery
Revision as of 12:16, 30 March 2007 by EdSells (talk) (version migrated from twiki)
Corner brackets
Clean the bars! They'll be your bearing surfaces later. You will need:
The tie bracket and 8mm bar act as spacers
Assembly rules:
- for each bar, one stub must be 20mm, the other end 28mm. - each block must have one 20mm stub and one 28mm stub.
Grub orientations face inside always (improves access later on)
Locate top layer with L70 8mm bars & a scrap length
Copy lower (previous) set, but
- ensure stub lengths are opposite to the one below . - start with the 20mm stubs as these only need the tie bracket to meaure the length. The opposite stub end lengths are already determined by the location pins.
Mark ends @ datum Tighten all bolts Stash
-- Main.EdSells - 30 Mar 2007
