Assembling An M8 Rroofl Frame
A Rroofl RepRap can be fabricated in a number of different ways. The closest to a true RepRap is probably the version using M8 threaded rod. This is extremely adjustable and great for experimentation, though could in theory be replaced with a cheaper, simpler stick-and-socket system for mainstream production. Americans can use 5/16" threaded rod if M8 is not available in your country.
Y Carriage
File:Y bed runners.scad Easy bit first. This is composed of two Y Runners held together with a couple of 130mm lengths of M8 rod. As with all assembly below, put a washer (usually M8 x 17mm) between the flat, plastic surface and every nut so the nut does not chew into the plastic. Bolt the two Runners together finger tight so they are spaced equally apart at the ends of the rods and the whole contraption will sit flat on the table. Then fully tighten.
Frame Side
Each of the two sides has a Foot Vertex, Double Foot Vertex and a Top Vertex all bolted together as before with M8 nuts, washers and two different lengths of M8 rod: 2 x 375mm and 1 x 310mm (though if you shorten them both by 20mm it'll all cut nicely out of a 1m rod; hmmmm).
Make one side, then temporarily hold the second side's parts to the first before tightening the second frame's nuts. Use the M8 bolts needed later for the X axis. This will allow you to assemble two frames with the holes in the same place, so thing stand a fighting chance of being parallel.
Belting The Y Carriage On
Ease the frame into shape on the rails, temporarily slackening the nuts if necessary. Y Slider legs can be compressed with a bolt or zip ties if it is necessary to level the bed. The actual deposition bed is attached by using 4 small double-sided foam adhesive pads. Clean the bed before sticking pads to it.The Y belt goes from the Y Runner, around the Y idler pulley, under the RepRap, back up around the Y motor drive pulley, over the Y motor idler and to the other Y Runner.
The Y belt is attached to the Runners with zip ties; Make loops in the belt ends and secure with zip ties. Thread another zip tie through the small holes in one side of the leg of the Y carriage, pass it through the loop in the belt and then use to tension the belt to your requirements. Note that if you leave a large loop of zip tie this introduces unwanted springyness, so you'll have to cinch it with a zip tie or two.
