AtomX
Description | AtomX
License | CC-BY-SA
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
About AtomX
This page where created so I can start uploading files and let beta testers do test prints of the parts.
This project where created during a weekend for fun and ended up to be a pretty cool micro bot.
Iam currently refining the parts and adjusting them and will be released 2016-03-27.
It can print all its parts on it self.
Use very little parts.
Cheap to build.
Printing Dimensions
X=105mm ( Should leave about 4-5mm )
Y=130mm ( Should leave about 10mm for belt fasteners etc )
Z=180mm ( Should leave about 20mm to add glas plate on bed and others)
Yes this gives you some space to put it on extremes to increase the print size on your machines :)
But I want it like this to keep it safe.
(Updated 2016-04-03)
Stl 3d print files
Latest complete files
http://reprap.org/wiki/File:Reprap_atomx_2016_04_07.zip
Obselete files
http://reprap.org/wiki/File:Reprap_atomx_files_20160331.zip http://reprap.org/mediawiki/images/0/03/Reprap_atomx_beta20160325.zip http://reprap.org/wiki/File:Reprap_atomx_x_motor_spacer.zip http://reprap.org/wiki/File:Rev2_reprap_atomx_x_fixed_parts.zip
BOM
Rods
2 = 170mm Long 6mm rods ( X )
2 = 200mm Long 6mm rods ( Y )
2 = 360mm Long 8mm rods ( Z )
2 = 220mm Long M6 threaded rods ( Structure support )
Leadscrew
1 = 300mm Long 8mm with Brass nut. ( Optional with a extra brass nut to place on the top side to minimize backlash )
Pitch of the leadscrew is up to you as there is many to choose from and easy to change in firmware.
Bearings
8 = Lm6uu
4 = Lm8uu
4 = 625zz ( Skateboard bearings )
1 = 608zz ( Skateboard bearing for top piece )
Bearings
2 = GT2 20 tooth pulleys ( Its up to you wath you use I had these at home.)
Belt
1 meter long GT2 ( Is more then enough and you get some left )
Nuts and bolts
4 = M6 nylon lock nuts. 4 = M6 nuts 2 = 47-50mm Long m3 screws ( X motor )
Hotend
Any Jhead or e3d clone should work.
Extruder
Any Bowden type like airtrippers or wades.
World premiere
( Videos have ads to fund my builds )
<videoflash type="youtube">iiAD7D7nIw4</videoflash><videoflash type="youtube">bEwji7QfVgc</videoflash> . <videoflash type="youtube">EeeoEcFTKqA</videoflash>
