Auto-centering shaft coupler
Revision as of 20:02, 1 December 2010 by TheOtherRob (talk | contribs) (Created page with '{{Development |image = IMG_20101201_175405.jpg |status = Experimental |name = Auto-centering shaft coupler |description = This should reduce Z motor movement when moving the Prus…')
Release status: Experimental
Description | This should reduce Z motor movement when moving the Prusa leadscrews
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This is my attempt at reducing z motor oscillation. Instead of a single clamp this shaft coupler uses two parts which zip tie together, centering each shafts into 2 triangular slots on either side of it.
I've yet to finish my Prusa to really test this out but from initial testing this looks to give a decent improvement over the original coupler in terms of wobble-reduction without any major reduction in axial holding force.
