Azteeg X1
Revision as of 16:56, 5 March 2012 by Royco (talk | contribs) (Documentation)
Work in Progress
Introduction
The Azteeg X1 3DP is an open source controller designed to be used in RepRap 3D Printers and similar cartesian based machines including CNCs. It has all the features needed to run all current and future single extruder designs.
The X1 is based on Sanguino/Sanguinololu and is compatible with most Arduino based firmware(Sprinter, Marlin, Repetier, plus others.). It is pin to pin compatible with the Sanguinololu with the addition of a FAN PIN. The X1 features mostly SMT parts to ease production and reduce cost.
Compatible with Pololu and Stepstick stepper motor drivers with the ability to use an external power source for the motors with higher voltages.
The Azteeg X1 3DP is your low cost, compact and expandable 3DP printer controller. Fully Assembled except for the white connectors where you have a choice between right angle and vertical orientation. Soldering iron required.
Features
  • Atmel ATMEGA 644P with FT232RL FTDI USB chip
  • Compatible with Sprinter, Marlin, Repetier, others.
  • Mosfet control for 1 extruder and 1 hotbed
  • Extra PWM control for small fan or LEDs
  • 3 end stops and 2 thermistor inputs
  • 12-30v input high efficiency switching Power supply @ 500ma max
  • Dedicated uSD card connector [SDRAMPS compatible]
  • Low RDSon Mosfets for less heat buildup
  • Input power selector for micro controller [USB or internal regulator]
  • Secondary power input for stepper motors.
  • Optional pads for TVS spike suppression diodes for the Mosfets
  • Mosfet Heatsinks included
  • i2C, Tx1 serial, +5, GND, SPI and ADC pins on the expansion ports
  • Fast acting blade fuse
  • Both right angle and vertical connector sets included
  • Lots of LEDs, Rx/TX serial, PWR, hot end and hot bed.
Images
Product Photos
Final version may differ slightly from shown.
User Photos and videos
<videoflash type="youtube">7gV8H0dhAhI|480|360</videoflash>
Early Prototypes
Files and Documentation
Schematics: http://files.panucatt.com/datasheets/azteeg_x1_schematics.pdf
Wiring Diagram: http://files.panucatt.com/datasheets/azteeg_x1_wiring.pdf
Test code (for Azteeg X1 and Sanguinololu 1.3): http://reprap.org/wiki/File:AzteegX1_Sang_testcode.zip
Where to get it
Pre-order at the For Sale forum. http://forums.reprap.org/read.php?94,122236
