Azteeg X1
Revision as of 01:48, 9 April 2012 by Royco (talk | contribs) (Hardware)
Work in Progress
Introduction
The Azteeg X1 3DP is an open source controller designed to be used in RepRap 3D Printers and similar cartesian based machines including CNCs. It has all the features needed to run all current and future single extruder designs.
The X1 is based on Sanguino/Sanguinololu and is compatible with most Arduino based firmware(Sprinter, Marlin, Repetier, plus others.). It is pin to pin compatible with the Sanguinololu with the addition of a FAN PIN. The X1 features mostly SMT parts to ease production and reduce cost.
Compatible with Pololu and Stepstick stepper motor drivers with the ability to use an external power source for the motors with higher voltages.
The Azteeg X1 3DP is your low cost, compact and expandable 3DP printer controller. Fully Assembled except for the white connectors where you have a choice between right angle and vertical orientation. Soldering iron required.
Features
  • Atmel ATMEGA 644P with FT232RL FTDI USB chip
  • Compatible with Sprinter, Marlin, Repetier, others.
  • Mosfet control for 1 extruder and 1 hotbed
  • Extra PWM control for small fan or LEDs
  • 3 end stops and 2 thermistor inputs
  • 12-30v input high efficiency switching Power supply @ 500ma max
  • Dedicated uSD card female header [SDRAMPS compatible]
  • Low RDSon Mosfets for less heat buildup
  • Input power selector for micro controller [USB or internal regulator]
  • Secondary power input for stepper motors.
  • Optional pads for TVS spike suppression diodes for the Mosfets
  • Mosfet Heatsinks included
  • i2C, Tx1 serial, +5, GND, SPI and ADC pins on the expansion ports
  • Fast acting blade fuse
  • Both right angle and vertical connector sets included
  • Lots of LEDs, Rx/TX serial, PWR, hot end and hot bed.
Images
Product Photos
Final version may differ slightly from shown.
User Photos and videos
<videoflash type="youtube">7gV8H0dhAhI|480|360</videoflash>
Early Prototypes
Files and Documentation
Schematics: http://files.panucatt.com/datasheets/azteeg_x1_schematics.pdf
Wiring Diagram: http://files.panucatt.com/datasheets/azteeg_x1_wiring.pdf
Test code (for Azteeg X1 and Sanguinololu 1.3): http://reprap.org/wiki/File:AzteegX1_Sang_testcode.zip
Getting Started Guide
Hardware
Tools required: Soldering Iron, Solder, Phillips Screw Driver.
1. Solder Connectors - The Kit comes with right angle and vertical connectors so you can choose which configuration is best for your installation. 0.1" pitch terminal blocks can also be used as shown above(Emmanuel's install).Inspect the solder joints after soldering to ensure a good and reliable connection, a loose pin or connector will be difficult to troubleshoot later.
2. Install Heatsinks - Use hardware supplied to fasten the heatsink, Thermal grease is provided but not required for normal operation. Straighten the heatsink before tightening the screws and check that both heatsinks are not touching each other. Use a long nose pliers to secure the heatsink while tightening.
3. Insert jumpers for step size - Consult your stepper drivers documentation to determine your step size settings. See wiring diagram for location and designations of the stepper pins. Push the jumpers all the way down to ensure good contact.
4. Solder TVS Spike supression diodes[optional] - These diodes help clamp down voltage spikes during on-off switching of the Mosfets. It is not required for normal operation but is highly recomended for stability of the board. The pads(SMB) for these are located at the bottom of the PCB near the Mosfet pins, they can be sodered in any orientation as they are non-polarized, bi-directional versions.
Warning-general-2.gif.png Caution
The TVS diodes supplied are rated for 16v, meaning you have to use a power supply lower than 16v(perfect for that 12v power supply of yours). You need to use a higher rated TVS diode if using a higher voltage power supply.
5. Solder SDRAMPS/uSD Carrier header[optional]
6. Install Stepper Drivers - The Azteeg X1 is compatible with the Pololu style A4983/88, stepstick and other similar drivers. Please wiring diagram for pin designations and driver orientation. Incorrect Placement will damage the board and drivers.
Where to get it
Pre-order at the For Sale forum. http://forums.reprap.org/read.php?94,122236
