BIQ Heater Block PCB
Revision as of 09:16, 27 November 2011 by Bodgeit (talk | contribs) (Created page with '{{Development |name = BIQ Heater Block PCB |status = experimental |image = BIQhb4.jpg |description = Revision 0.1 |license = CC BY-NC-SA 3.0 |author = Bodgeit |categories = [[:Ca…')
Release status: experimental
Revision 0.1
CC BY-NC-SA 3.0
Eagle
Introduction
A small low cost RepRap compatible heater block PCB.
Another simple BIQ new PCB designs is heater block connection PCB with Led ilumination around the Extruder so you can see what is printing and control the mounting of temperature sensors on the heater block. This is the 4mm version for 1.7mm feed stock designed for use on Huxley Seedling but can be used on All RepRaps.
To be updated with files and pictures once the first PCBs arrive.
