Baboi
Revision as of 00:14, 26 October 2013 by Efuntime (talk | contribs)
Baboi v1.1
Release status: Working
All-In-One 3D Printer Controller Arduino MEGA based modular RepRap electronics.
3D Printer | Electronic: Baboi Box Baboi board is one of the most compatible 3D Electronic board in the reprap community.
1 .It's an all-in-one 3D printer controller that allow you to fully control your 3D Printer without connecting to any other devices.
2. Once you have this controller, you can basically use it for any kinds of stepper motors based 3D printers that you can find in the reprap.org. Which also includes the most popular models like Prusa and Original Mendel.
3. It's an easy to use and easy to install Electronic kit that never before, Everything is pre-labelled, properly set up and well organized. All you need to do is finding the right pins and make simple connections.
Features
Integrated all useful function into one 4 layers electronic board
Features:
  • Atmel ATmega 2560 with ATmega16U2
  • Flash Memory: 248KB
  • SRAM: 8KB
  • EEPROM: 4KB
  • Input Voltage: 12V
  • clockSpeed: 16MHz
  • MircoSD slot: Yes
  • LCD pins: Yes
  • Joystick: Yes
  • Motor Driver: 4 x Integrated Allegro A4982
  • PWN Fan: Yes
  • Heatbed: Yes
  • Endstops: 4
  • External Serial ports: Yes
  • External I2C ports: Yes
  • External Reset Pins: Yes
  • Four integrated Allegro A4982 Stepper Driver
    -Thermal shutdown circuitry
    -Short-to ground protection
    -Shorted load protection
    Build-in Push-Push microSD card socket
    2 N-MOSFETs for Extruder and Heatbed control 1 N-MOSFET for low power PWM Mosfet driven outputs
    External Reset button for emergency stop
    External 5V supply and GND for any other modules
    External Joystick connection pins for manual control
    External LCD connection pins for standard 20x4 LCD
    Extra pins available for Raspberry Pi expansion and development;
    RX,Tx and GND
    SDA, SCL and GND
    Physical Characteristics
    4-Layer PCB with proper ground plane and power distribution networks The maximum length and width of the Baboi are 115 and 60 mm respectively, with the USB connector and power terminals extendng beyond the former dimension. Three screw holes allow the board to be attacted to a surface or case. Baboi is deigned to be compatible with most of 3D printers in the current market. Further from that, UART(serial port) is also connected as external pins for Raspberry Pi for further development uses.
    USB overcurrent Protection
    Babo has a resettable polyfuse that protects your computer's USB ports from shorts and overcurrent. Although most computers provide their own internal protection, the fuse provides an extra layer of protection. If more than 500 mA is applied to the USB port, the fuse will automatically break the connection until the short or overload is removed.
    3 Modes for Baboi Box:
    1. SD Card Printing mode
    You can store all your gcode into MicroSD card and inserted into Baboi box, It would automatic read your gcode and start printing after it reach its printing temperature. Sd printing.jpg
    2. Manual Control Mode
    This mode is perfect for open source 3D printers, as we all known open hardware 3D printer is not as stable as other finished products. So that you will find this mode very useful when you first time set up your printers or when you fix hardware problems. It's an easy-to-use hardware testing function.
    3. PC Mode
    For people who still like to connect your 3D printer to Computer, here's the mode that you probably would use.
    Baboi Box - ALL IN ONE - 3D PRINTER CONTROLLER KIT
    Functionality
    One Baboi Box= Arduino Mega 2560 + Ramp 1.4 + (4x Motor Drivers) + SD card Reader + 20X4 LCD Display + Joystick controller + Cooling Fan + Laser cutt wood case + (Software upgraded with 3 modes) + hardware setup + fully tested
    Open Hardware:
    For people who are interesting in its design, you can find it here: Media: Eagle_files_of_Baboi_v1.1.zip
    Links
    www.efuntime.com
